Replaced timing belt- now having issues!
Old Feb 28, 2009 | 06:47 PM
FSUseminoleEM1's Avatar
Default Replaced timing belt- now having issues!
Okay so today on my b16A2
1) Had my camshafts replaced with GSR's cams and cam gears (buddy club)
2) Had my timing belt & water pump replaced too.
Now my problems are:
1) Battery light illuminates when I give it a lot of throttle.
2) Car dies while idling
3) Squeaking belt from the lower block area-ish...I'm sorry I don't know how to better describe it.
I've had one friend tell me that means the belt is too tight, and another say it's not tightened nearly enough.
Anyone else have suggestions??
Thanks in advance!
Old Feb 28, 2009 | 06:50 PM
KillBot's Avatar
Default Re: Replaced timing belt- now having issues!
Alternator belt loose?
Old Feb 28, 2009 | 06:53 PM
When replacing timing belt & what not, would they have had to loosen the alt. belt? and so maybe they forgot to re-tighten it?
Old Feb 28, 2009 | 06:55 PM
KillBot's Avatar
Yes. They would normally remove/replace all accessory belts to replace the timing belt.
Old Feb 28, 2009 | 06:56 PM
okay...wow that's frustrating. Wish I could do more of my own work.
But do my "symptoms" sound typical of a loose alt belt? Anything else to look for when I go in there?
Old Feb 28, 2009 | 07:00 PM
KillBot's Avatar
Everything sounds right.
Are your headlights/interior lights changing brightness?
Old Feb 28, 2009 | 07:04 PM
nah not really. I'm still getting 12.5 - 12.8 volts at the battery. It really must be that belt b/c the more gas I give it- the more it squeaks.
Old Feb 28, 2009 | 07:08 PM
Sr420Det's Avatar
If you can turn it 90 degree than its not tight enough, check both belts. The timing belt may be off a tooth.
Old Feb 28, 2009 | 07:33 PM
all right thanks guys.
dleccord
Apr 13, 2020 08:03 AM
airikkCRX
Apr 2, 2010 08:29 AM
civic=goodgasmileage
Honda Civic (2001 - 2005)
Oct 11, 2008 09:17 AM
JDMtype Eg6
Feb 18, 2007 05:45 AM
blayzenazn
Feb 18, 2002 07:51 AM
