88 CRX PROBLEM!! Help
I have an 88 honda crx DX. im having problems with my rpms jumping and i have lost a lot of power. rely only noticing it when u floor the gas. Just took IAC valve off and cleaned but still no improvement. new alternator, distributor cap, battery, fuel pump and tank, new master cylinder. could the IAC valve be the cause of this? or can i adjust it to fix the problem. Help please
sounds like it could be a timing issue, or your coil pack is going out.
Did you mess with the timing lately?
when did this problem start happening? right after the cap install maybe?
right after i put cap on it ranfine for about a week then messed up again. new plugs not wires the rotor looked fine. also a new ignition coil i forgot to add. havent messed with the timing
i would have to agree on the timing and if that doesn't work it might be your icu (idle control unit) i had the same problem with mine
axfireinside
Jul 31, 2012 07:45 PM
D@9 A.D.B.
Jun 30, 2008 04:22 PM
DK4200
Oct 8, 2003 05:09 PM
