What could be the problem?
Old Feb 28, 2009 | 01:05 AM
roni_xxp's Avatar
Default What could be the problem?
My car was running fine couple days ago and today i replaced the ect sensor the car has a vss sensor problem so whats happening is i cant pass 4k rpm im using a p28 on h22 motor with ectune on 92 prelude t3/t4 turbo and the launch control was set to 4k or so but if i step on the clutch while the car is moving the rpm can reach to redline and if i boost it on 4th gear the pressure can reach to 10psi which is good but when you reach almost 4k it will bug sounds like the launch control, could this be my vss sensor or boost leak? Any suggestion would be nice..
Old Feb 28, 2009 | 01:19 AM
SadKorean34's Avatar
Default Re: What could be the problem?
first problem is..
you posted this in wrong sub-forum.
Old Feb 28, 2009 | 11:43 AM
TsujenDB1's Avatar
The problem is you're in the wrong section.
https://honda-tech.com/forums/honda-prelude-4/
Old Feb 28, 2009 | 11:54 AM
JRSC EM1's Avatar
car aids. Its fatal.
Leandro Peņa
Honda Civic (2001 - 2005)
Sep 26, 2018 08:32 AM
roni_xxp
Engine Management and Tuning
10
Mar 1, 2009 03:14 PM
roni_xxp
Mar 1, 2009 03:30 AM
Speed PHreak
Mar 26, 2002 04:24 PM
Speed PHreak
Mar 18, 2002 02:48 PM
