Wire tuck write up?
I've done several different searches but there is no EJ specific wire tuck write ups that I could find as the search engine I guess is still have problems, that or it just sucks?
If anyone has a wire tuck how-to subscribed or anything or could show me how to get around to it thatd be great. This EJ is ALOT more cramped than my old EF haha.
I can give you tips lol...
My current wire tuck might be giving me some problems :/
Tuck the overflow tank IN FRONT of the radiator. There is a hole there in which you can bolt it in. I can get you pics if you want.
I'm tucking wires. Not hoses haha. Coolant over flow doesnt bother me, I'm not going that into it, just the fuse box, battery and headlight harnesses.
Got the blower motor out and pulled the fuse box wires through got to extend the starter wire. Gotta get that fed tax return check in so I can go get more wire and terminals to relocate the battery. That blower motor was a bitch.
I need a diagram of some sorts as to which wires to extend and where to run the passenger side headlight harness as well as the drivers side.
Pictures and information would be very much appreciated. I'm sorry for not lurking around the net enough to find a write up.
for both sides of the engine bay harness (or headlight harness, etc)... u route them throu the frame...drill a hole through the frame big enought for the wires and a large grommet... cut the harness...run it through...the sauder wires back together on OUTSIDE of frame...run the wires along the frame (behind the fenders) and up to the headlights...etc...etc.... good luck1 its a bitch
https://honda-tech.com/forums/showth...ight=tuck+wire
Check out this thread. Might be of some help. If not try contacting ChaseBays on here, he might have some diagrams or some tips for ya.
I've done wire tucks before just not on a EJ or EK. Just didnt want to extend things that dont need to be extended. Thanks guys!
SlowPokeEg
Apr 13, 2008 03:29 PM
