Timing
Old Feb 27, 2009 | 10:56 AM
denso's Avatar
Default Timing
hello, so here is the question, i have a 92 civic si and the timing is off! but wait, It can't match the mark even if we try to turn the dizzy, we got the timing gun and checked, What could be the reason why? could it be the pully itself or the belt,?
Any help, would be appreciated, thanks in advance.
Old Feb 27, 2009 | 10:17 PM
mmhoward1's Avatar
Default Re: Timing
Did you jumper the jumper the grn\wht and the brn connector above the passenger kick panel before checking it?
Old Feb 27, 2009 | 11:24 PM
trustdestruction's Avatar
Default Re: Timing
+1
and did you hook the pickup wire to the spark plug wire on cylinder 1? (closest to driver's side)
If you did both of these things right, has your timing belt been replaced? It's possible that the engine wasn't timed properly when the timing belt was installed.
If the belt is old, it's possible that it skipped a tooth.
Freedomstricken
Apr 26, 2019 04:33 AM
naeem.ca
Jul 15, 2018 08:06 AM
ziffies
12
Feb 8, 2013 04:50 PM
THE-SHIZZLE
Jun 1, 2010 08:42 AM
slo gto
Dec 24, 2008 12:02 PM
