overheating at the track.....help!
Old Aug 10, 2002 | 10:06 PM
Petah's Avatar
Default overheating at the track.....help!
My car is overheating whenever i road race it. It doesn't over heat badly because if i turn on the heat, it will run fine for the day. But i have already mixed the coolent to be 30/70 and the thermostat has already been replaced. Is there anything else i should look into besides that? I am also running a delsol dual core rad. It didn't do this before and just started for the past 2 lapping days. Thanks.
[Modified by eg-six, 11:30 PM 8/10/2002]
Old Aug 10, 2002 | 10:30 PM
BagelW's Avatar
Default Re: overheating at the track.....help! (eg-six)
Have you put any additives in the radiator to help with cooling? I think there are a couple of different ones to use but I can't remember the name of them. Anyways, they can make a difference when you're running on the track.
Old Aug 10, 2002 | 10:50 PM
_BEN_'s Avatar
Have you tried...
-Water Wetter? I think redline makes it its only like 6 bucks.
-A higher pressure radiator cap 20bucks.
-Spoon (for example) makes a radiator fan switch that activates at a lower temp 70bucks.
All of these together would cost under 100bucks and could solve your problem if it isint too extreem.
Ben
[Modified by nosepkr, 4:51 PM 8/11/2002]
Old Aug 11, 2002 | 08:21 AM
deepnite's Avatar
Default Re: overheating at the track.....help! (nosepkr)
water wetter could hook up ur fan so it runs all the time too
Ryebread1974
Sep 24, 2018 04:24 PM
x justin
Feb 17, 2015 05:02 PM
integraNooB
Jan 15, 2008 06:19 AM
Cyber ITR
Aug 7, 2007 10:48 PM
Al-sonic
Jan 12, 2007 10:38 AM
