CV joint going out?
Old Feb 27, 2009 | 04:26 AM
DOHC hatchback's Avatar
Default CV joint going out?
I have a 93 EG with a Gsr swap/B16 tranny. the last two times Ive drove it I noticed after I drive it for a while When I let off the gas the car jerks to the Left and I hear A popping noise. I drove it yesterday and got on it a couple of times and It didnt happen at all.
Old Feb 27, 2009 | 10:49 AM
thegoudster's Avatar
Default Re: CV joint going out?
Make sure all of your lug nuts are tight.
Old Feb 27, 2009 | 10:53 AM
P12 EG6's Avatar
ok first thing to do, if is unlikly a cv joint would cause this, i suggest you jack up the car, look at all of the suspention bolts/ nuts on boath sides, my friend didnt tighten a bolt on the LCA and the bolt un threaded and then the car had a jiggle and a constant pull to one side, and check the lugs.!~
Old Mar 5, 2009 | 03:41 PM
ok guys ill let ya know
Old Mar 5, 2009 | 03:48 PM
callmechad's Avatar
i also have a clicking noise when i turn left or right sharp. so when you turn the clicking noise doesnt mean its your cv joint? it could mean that i got loose nuts and bolts?
Old Mar 5, 2009 | 04:15 PM
hoffmanb16's Avatar
clicking means bad c.v's
Old Mar 5, 2009 | 06:48 PM
callmechad's Avatar
aww damn i thought i was ganna save some money lol
Old Mar 5, 2009 | 07:32 PM
xshortx's Avatar
its gunna cost about 20 bucks each cv boots with the lube
Old Mar 5, 2009 | 08:33 PM
Jimster480's Avatar
change the boots and put new grease on it. Hope that they are fine :X
Old Mar 5, 2009 | 08:46 PM
iluvmyhnda's Avatar
i bet its got something to do with your axle, either the splines on either end or maybe the inboard joint. put it in the air and rotate the driveshaft with your hands with the car in gear and inspect it that way.
Old Mar 5, 2009 | 09:19 PM
pacific4door's Avatar
Icon3 Re: CV joint going out?
Ya time for a new CV. The pulling hard to one side could be as simple as improper inflation in your tires
Old Mar 5, 2009 | 09:30 PM
Uberfit's Avatar
How come I post this same problem in much more detail and need to bump it three times before I even get one response, and this thread has 10 replies in one day? ...sigh... I am having this same problem, I also think it might be the CV joints because I have been reading about the clicking noise which I have, and when I let go of the gas I get shaking pretty hard and pulling to the right, but only sometimes... I have a '95 Del Sol Si with a d16z6.
Let me know if you get this fixed what the problem was, I am going to florida for the week so I won't be around to check it out myself til I get back, but if you have other issues that I should look at too, maybe I can save myself some grief. THANKS! and goodluck
Old May 25, 2009 | 08:07 PM
luispizarro25's Avatar
bump, anyone with this issue solved. i got the same after swap gsr into EJ1
skater5067
23
Apr 4, 2023 09:19 AM
my94d16y8coupe
Oct 18, 2011 03:28 AM
FTNW
Oct 24, 2010 02:50 PM
importboi22
Southern California
Apr 9, 2010 12:52 AM
accordfreak
Jul 22, 2003 10:58 PM
