H22a timing belt issue please check out
Old Feb 26, 2009 | 07:38 PM
EJ6SON's Avatar
Default H22a timing belt issue please check out
ok so being the newb that i am I attempted to do a auto to manual swap for my timing belt tensenor. Well what iv'e done so far was remove the crank pully and the gear behind it the valve cover is off and well i did not line up the motor TDC when i removed the crank pulley. What should i do now? Should i continue with the swap or would i be able to put it back on then align the motor then continue? the timing belt is still on the only thing i have removed is the crank pulley. Please give me some light if any to help thank you.
its a 94 jdm h22a /5 speed
Old Feb 27, 2009 | 08:57 AM
mouab18c1's Avatar
Default Re: H22a timing belt issue please check out
if you havent touched the belt is should still be on right..just put the crank pulley back on and align the tdc mark on crank pulley with the pin mark on the lower timing belt cover
Old Mar 2, 2009 | 11:48 AM
EJ6SON's Avatar
cool thank you.....
ThA IntegrA HI
Dec 17, 2009 06:37 PM
Annihilator
Jul 23, 2008 01:32 PM
Powered by VTEC
Jan 29, 2008 05:58 PM
94dxt
Oct 27, 2004 12:36 PM
Slipknt777
Jun 25, 2004 02:51 PM
