FMU on a N/A b16a?
Old Feb 26, 2009 | 06:55 PM
longshot's Avatar
Default FMU on a N/A b16a?
does anyone know if this would help at all? thanks
Old Feb 26, 2009 | 07:23 PM
turbojdmhatch's Avatar
Default Re: FMU on a N/A b16a?
why would it help...and FMU's dont help anything...this thread should have not been created
Old Feb 26, 2009 | 07:40 PM
bossm's Avatar
What is an fmu?:
A Fuel Management Unit (FMU) is a special rising rate fuel pressure regulator placed in the fuel return line of the fuel injection system. This is a very common approach to handling the increased fuel demand required by turbo kits and supercharger kits. It does work. It will make the injectors flow more fuel than their rating. These are used in addition to the factory or aftermarket fuel pressure regulator and only have an affect under boost.
FMUS are rated by the ratio of fuel pressure to boost pressure. For instance, a 10:1 FMU will give you 100psi fuel pressure at 10 psi boost pressure.
Why you shouldn't run an fmu/missing link?:
Fmu's are considered a "hack" they overload your injectors with high fuel pressure to compensate for boost pressure. This is the improper solution for fuel management on a forced induction vehicle. Most stock engine computers do not retard timing under boost hence causing dangerous engine conditions. A missing link simply stops the manifold pressure sensor from seeing positive pressure, hence preventing a check engine light.
Old Feb 26, 2009 | 07:48 PM
en00be's Avatar
n00b banned bet ur butt hurts
ekk41
Dec 19, 2007 08:51 PM
huge230
Mar 3, 2007 01:53 PM
JDMH22
Feb 23, 2004 12:30 AM
b16ahybrid
Nov 28, 2002 07:51 PM
evil_elmo
Oct 13, 2002 02:15 AM
