EK raybrig fog light install - HELP!
Old Feb 26, 2009 | 05:33 PM
enot767's Avatar
Default EK raybrig fog light install - HELP!
Alright, so i got a sir front bumper, with oem raybrigs and a oem harness.
1) plugged the brown plug in the engine bay to the one from the fogs, and grounded the wire coming from the fogs
2) i went under the dash and plugged the under dash harness into the another brown plug
3) plugged hi-beam harness portion in
4) hooked up the relay box and ground
i might be missing a element, and theres a inline fuse on one of the wires but pretty much i plugged in everything. I turned my car to accessory, turned my headlights on, push the oem fog light button -green light lit up-, went outside of my car and nothing! no light!
possible ideas where i went wrong:
1) dead bulbs/no bulbs?
2) fuse my be blown?
3) is there supposed to be something that goes into the fuse box? i keep reading that im supposed to put some plug into the the fuse box under the dash?
Old Feb 26, 2009 | 06:52 PM
Arthas's Avatar
Default Re: EK raybrig fog light install - HELP!
Dude, check if there is bulbs lol.
I hate using the OEM spec harness it comes with. Its so confusing and they turn off when you turn on your high beams.
I got a $19.99 harness from Pep boys that comes with wiring, relay, and switch. It allows you to wire them up to your OEM spec button switch, and you can have them turn on whenever your corner lights are on. I love it this way.
Old Feb 26, 2009 | 07:00 PM
enot767's Avatar
ill check tomorrow. lol i would make that mistake.
and yeah i was thinking the same thing, my buddy is going to wire them up for me that way tomorrow if we cant get it to work
so using the oem underdash harness, does ANYthing go to the fuse box? it has a inline fuse but i keep reading theres supposed to be a fuse in one of the empty power sockets or w/e ones for ignition, accessory, and constant
Old Feb 27, 2009 | 02:23 AM
Arthas's Avatar
For 99-00 you have to use the fuse box in the kick panel, not sure about 96-98.
But then again, I like using my Pep Boys harness.
zXeX
Sep 2, 2009 07:34 PM
amej8
16
Jan 4, 2007 08:02 PM
KtHaNxBai
May 25, 2006 10:37 AM
EJ8VTEC
14
Dec 12, 2005 02:37 PM
Yezzzeeerrr25
Aug 21, 2005 06:39 PM
