Plans for an all motor build
So, my thread didn't work out so well in the tech/misc section, so I thought I'd try here.
I just wanted to get an opinion from everybody to see if the parts I want are good or not. I haven't gotten started on my build yet, because I didn't wanna just start buyin random parts cuz I know if I make a mistake it'll do more harm than good.
Here's my list:
Mishimoto radiator
Samco radiator hoses
AEM intake (already have)
BDL 66mm throttle body
Skunk2 Pro Series intake manifold
Hondata intake manifold gasket
B16B cams
B18C-R pistons with rings set
NGK Power Cable with NGK V-Power spark plugs
Walbro 255LPH fuel pump with Walbro fuel filter
Skunk2 composite fuel rail
RC 310cc fuel injectors with RC clips
Comptech header
RS*R Ex-mag exhaust
Skunk2 magnetic drain plug set
J’s Racing torque dampener
ACT streetlite 12lb flywheel
Of course once I finish, I'm gonna get it tuned. Does anybody have any thoughts on what else I should get or if there's anything on the list that I shouldn't get? Oh yea, I have a stock gsr motor. I'm tryna keep as many parts CARB legal as possible. My goal is to get around 190+ whp and my budget is around 5000. Any recommendations would help a lot. Thanks.
Here's my list:
Mishimoto radiator
B16B cams
Comptech header
RS*R Ex-mag exhaust
The reason no one responded is because your list is childish. We dont need to know about SAMCO hoses, or magnetic drain plugs, what type of radiator, plug wires, etc.
Here's my list:
B16B cams (ITR cams will do the same)
B18C-R pistons with rings set (USDM or JDM?)
Walbro 255LPH fuel pump with Walbro fuel filter (Stock GSR will be plenty)
Skunk2 composite fuel railno need
Comptech header (you’ll need a better header to reach your goal, Tri-Y)
RS*R Ex-mag exhaust
Here's my list:
RS*R Ex-mag exhaust
Valve Springs, and an ECU for tuning.
You will not get to 190whp on Dynojet with your current list, close, 180's at least.
Here's my list:
Mishimoto radiator--> Skip
Samco radiator hoses--> Skip
BDL 66mm throttle body--> Maxbore.com
B16B cams
Walbro 255LPH fuel pump with Walbro fuel filter--> Skip
Skunk2 composite fuel rail--> Skip
RC 310cc fuel injectors with RC clips--> for 190whp stock is fine
Comptech header
RS*R Ex-mag exhaust
Skunk2 magnetic drain plug set--> Skip
J’s Racing torque dampener--> Skip
ACT streetlite 12lb flywheel--> Skip
Yeah....I'd have directed him to the FAQ thread to read about some of the successful builds there have been out there to get some idea of what might be needed to reach his power goal.....
Then, noone would call your thread(s) "Childish" and you might get actual answers b/c people feel like you've actually put some effort into finding the information, yourself.
Just an idea.....
Here's my list:
Mishimoto radiator
B16B cams
Comptech header
RS*R Ex-mag exhaust
Here's my list:
Mishimoto radiator
B16B cams
Comptech header
RS*R Ex-mag exhaust
http://cgi.ebay.com/ebaymotors/JDM-H...QQcmdZViewItem
My bad, I missed the faq stickie on top. I did a search on some builds and I'm starting to see what's most popular and successful. Thanks for the help tho.
TheProffessa
24
Nov 17, 2011 01:11 PM
