B20B timing question
Old Feb 26, 2009 | 10:19 AM
B18_Civic's Avatar
Default B20B timing question
I am swapping a B20B in to my car. I am wanting to change out the timing belt for obvious reasons and i had some issues. I had to use the LS crank pulley off my old motor because i didnt have a B20B crank pulley. I noticed that when i put the motor to TDC based on the crank pulley the cams gears were off. Naturally when i get the cam gears to line up the crank is off. My question is: Is the LS pulley and the B20b pulley the same. I know that they are different in diameter but are the timing marks the same comparative? I typically dont do newtopics because I am very fond of the search button and find my answer most of the time. I might just not be using the correct key words for it but i have resorted to this. Any help is help to me. Thanks.
foolsforever
11
Aug 9, 2018 05:08 PM
Built4Battle
Dec 23, 2013 01:57 PM
suje
14
Feb 22, 2012 04:19 PM
Xemu
28
Apr 22, 2007 01:56 PM
pokemon
May 20, 2003 08:38 AM
