ebrake?
so i bought the car a while ago and the ebrake doesnt work at all.
how do i go about tightening it? or should i replace the cable and how hard is that?
its a 91 hatch
its a 91 hatch
Replacing the cables isnt difficult at all. 2 bolts and a pin to remove the cable from the trailing arm and 3 12mm bolts holding down the cables down the trailing arm and frame.
Yes, if you look at the cover it has to tabs that can be removed. Remove the one towards the front of the car. And it should have the scres I believe. Check your pm's before you get flamed for suck a newbie question.
Civicman86
16
May 12, 2007 01:07 PM
