do brake pads require the shims?
Old Aug 10, 2002 | 06:19 PM
frogsr's Avatar
Default do brake pads require the shims?
one of my brake pad shims in the front broke, but i just stuffed it back in. it was rubbing up against my rotor's hat area and grooved it from contact. are these outer shims required for proper brake function, or can i take them off? any bad consequences taking them off? thanks in advance.
Old Aug 10, 2002 | 06:25 PM
57one's Avatar
Default Re: do brake pads require the shims? (frogsr)
I have 93 hatch and I took the shims off of my car. It hasn't effected anything. The only thing I notice is that the brakes squeal a bit more than usual.
[Modified by 57one, 3:26 AM 8/11/2002]
Old Aug 10, 2002 | 07:29 PM
Chiovnidca's Avatar
You may notice a little more noise. Maybe not.
Old Aug 10, 2002 | 07:53 PM
smokin rubber's Avatar
Default Re: do brake pads require the shims? (Chiovnidca)
yes, the main purpose of the shims is noise reduction.
Old Aug 10, 2002 | 08:39 PM
3rdGteg's Avatar
Default Re: do brake pads require the shims? (smokin rubber)
Just rub some of that stop squeak glue-like substance on the back of your pads and your set.
Old Aug 10, 2002 | 09:40 PM
frogsr's Avatar
thanks for the replies fellas.
so... performance will not be affected--only noise may result, right?
Old Aug 10, 2002 | 10:49 PM
Loco Honkey's Avatar
Default Re: do brake pads require the shims? (57one)
So it did affect something...
Old Aug 12, 2002 | 03:22 PM
cobalt's Avatar
New User
Default Re: do brake pads require the shims? (F=WT)
Shims are essentially noise-reducing agents...most modern brake friction compounds, due to their semi-met composition, will tend to squeal...and thus pads that are sold as OEM-replacements will typically use one or more of the following noise-reducing methods:
(1) edge chamfering
(2) shims
(3) slotting
If you don't have shims, you'll just live with some noise. You can use Permatex Disc Brake Quiet to reduce noise if it bothers you too much...get it at Autozone or Pep Boys in the 12oz aerosol can...easier to apply.
HTH... -Andie
philkehn
22
Mar 8, 2023 11:11 AM
ramoneguru
Jun 16, 2005 02:30 PM
lo0nY
11
Feb 20, 2005 10:57 PM
CerealKiller1117
Sep 18, 2003 10:05 PM
KingJeff
Sep 9, 2002 10:48 AM
