Ls vtec wont run, help
I Have an lsv in my EF hatch and it wont idle or rev up when i mess with the map sensor and the vacuum lines it trys to stay runing but acts like its not getn fuel but it is and it has spark im runing a pr3 ecu but i dont have a knock sensor installed. what could it be thats not letn my motor run? any info would help.
thanks
thanks
when i use the map sensor thats on the fire wall and attach the vacuum lines to the manifold i can get it to start but when i use the map sensor thats on the tb and i plug the vacuum ports off on the manifold it wont start ive tried to find a vacuum diagram but havnt found anything for a setup like mine.
Tell ya what, try posting in the Hybrid or Tech misc forum as CC mentioned. If you need repairmanual diagrams try HondaHookup.com for PDF versions of the Helms manual for your Car/Engine.
smashed4thgen
Oct 12, 2003 08:12 PM
