she starts then cuts off
Old 07-01-2009, 01:09 PM
bLu92bUbbLe's Avatar
Default she starts then cuts off
i finally put this ls motor in that i got weeks ago....timing is straight and wiring seems to be ok...my problem is when i go to start it she cuts right back off...i have 2 keep gasing it to keep it on...i checked the sensors...the car (92 dx hatch) also has another map sensor on the body of the car with a hose stickin out of it....does any1 know where this hose goes to...
Old 07-01-2009, 01:55 PM
ek-g6's Avatar
Default Re: she starts then cuts off
I dont think that other sensor is a map sensor. I think it is the purge valve for emissions. one should connect to intake manifold, and the other will connect to the charcoal canister.
Old 07-01-2009, 04:40 PM
u talkn bout right next to the map sensor...the hose that connects to that piece from the canister????
Old 07-01-2009, 05:13 PM
Former User's Avatar
Is the CEL ON?
Unplug the connector to the MAP sensor on the firewall and also disconnect the vacuum hose. Then plug the MAP sensor connector into the MAP sensor on the throttle body and block up the vacuum hose to prevent a vacuum leak.
Old 07-02-2009, 02:46 AM
this is what im talkin bout
Old 07-02-2009, 07:53 AM
Is the CEL ON?
If the vacuum hose in the your hand is plugged, then it's fine. Now unplug the connector on the firewall MAP sensor in the picture and plug this connector into the MAP sensor located on the throttle body.
Old 07-02-2009, 10:07 AM
THE BULL's Avatar
obv a vac leak somewhere
Old 07-02-2009, 10:11 AM
yea i cant find the leak tho...
Old 07-03-2009, 04:49 AM
bump.....
Old 07-06-2009, 12:00 AM
bump.....
da9blk1
10-16-2007 02:41 AM
Topdawgg
06-25-2007 10:02 AM
jay-d-em
09-07-2006 05:07 PM
HondaCutter
09-23-2002 09:41 AM
Quick Reply: she starts then cuts off
