Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
PART ID REQUEST: OEM Electrical Connector???
Old Feb 25, 2009 | 05:31 AM
FastTimesAtFGHigh's Avatar
Default PART ID REQUEST: OEM Electrical Connector???
This is a shot in the dark but hopefully some of you DIY gurus out there will recognize this part and provide a part ID for me.
What OEM Honda part is the green connector pictured below? This is DIY harness that someone made for the CTR start button in 2006+ civics. The creator refuses to share the part number and is asking for $100 to make these simple harnesses for people!
Anyhow, bestow your knowledge if you can ID it! :D
Thanks!
Old Feb 25, 2009 | 07:39 AM
Zeusone's Avatar
Default Re: PART ID REQUEST: OEM Electrical Connector???
pics does not work. you can use the hazard or vsa or fog light harness for the push start.
Old Feb 25, 2009 | 11:33 AM
kmm's Avatar
kmm
New User
the green connector is the same as for the fog light switch, vsa, and even the stock honda navi system. but I just dont know where to get them from (suppliers would be best but a store will do) also the brown connectors plug into the power harness leading to the ignition and acts like a bypass to the ignition to make the CTR start switch posible with out cutting anything...
I guess what FastTimesAtFGHigh and I are looking for is leads as to who makes the connectors, is there a cheep chinees knock off that we can get and what are the part numbers if any
Old Feb 25, 2009 | 01:35 PM
Zeusone's Avatar
any 03 or so new honda will have them. just look at a wrecking yard.
Old Feb 25, 2009 | 05:37 PM
jdmeg9's Avatar
where was this bought from? i would deff be interested if i don't have to cut anything on my stock harness
Old Feb 25, 2009 | 05:57 PM
jdmeg9's Avatar
my eg sedan had that same kind of green harness for the defrost and foglights i believe
Old Feb 25, 2009 | 06:43 PM
kmm's Avatar
kmm
New User
ya they are kind of indutry wide, they are used in volvo trucks and so many other things ... there is a user on the other forum that is making and selling them for 100$ it's some what of a good price but against what I do (DIY or nothing) I know you can buy this stuff in bulk (just the ends nothing else) but I cant find that site again, the last time I looked at it was like 2-3 years ago
Old Feb 25, 2009 | 06:48 PM
kmm's Avatar
kmm
New User
here is one place I found but only for the green one not the brown ones
http://geekeng.techxpress.ca/index.p...id=1&Itemid=53
and the green one it self is 10$
Old Feb 25, 2009 | 06:59 PM
kmm's Avatar
kmm
New User
I think they are make by these guys but I can find the right ones they dont list a 5 pin
http://catalog.tycoelectronics.com/T...&RQPN=776204-2
see if one of you guys can find it, I killed 4 hours on there at work today looking around, I must say though they sure as hell have a lot of other neet stuff
Old Feb 26, 2009 | 02:17 AM
jdmeg9's Avatar
who sells this harness though?
if you don't want to tell me in the forum to give them business pm it to me then please
Old Feb 26, 2009 | 05:13 AM
if that's the case, then the VSA switch is only a measely $6.70 from http://www.hondaautomotiveparts.com
2892704 014 SWITCH ASSY., VSA OFF
Old Feb 26, 2009 | 12:34 PM
kmm's Avatar
kmm
New User
the switch it self means nothing it will not come with any plugs/connectors sure it uses the same type of connector but you will still need to buy one
Old Feb 26, 2009 | 07:11 PM
jdmeg9's Avatar
where do they get the brown harness's?
Old Feb 26, 2009 | 08:18 PM
kmm's Avatar
kmm
New User
ya I would like to know that myself too, the male would be somethat easy to take off a scraped car but the female side would be harder to find as it is part of the switch asm.
Old Feb 27, 2009 | 01:19 PM
so here are the connectors my contact at honda parts has at his disposal:
he said the 2005 civic fogs have a similar connector as well. what do you think guys?
Old Feb 27, 2009 | 02:32 PM
kmm's Avatar
kmm
New User
they will not work it needs to look like this
you can get it here (http://geekeng.techxpress.ca/index.p...mart&Itemid=53) for 10$ if you want
Old Jun 1, 2010 | 09:27 AM
DANNYCAVS's Avatar
anyone have any idea where to get this connector that goes to the back of the push start button???
Old Jun 17, 2010 | 06:06 PM
jdmeg9's Avatar
I would like to find someone that sells the start button and garnish together. Password has the button but I couldn't find the garnish on there site
Old Jun 17, 2010 | 07:43 PM
av911's Avatar
Make your own harness, it's not that hard.
LowFlyin'
Mar 22, 2026 10:31 AM
superchargedY8
Lighting
Apr 21, 2009 10:15 AM
superchargedY8
Apr 7, 2009 07:09 PM
DavidHLX
12
Jan 9, 2009 10:55 AM
nacnud_z24
Honda Civic (2001 - 2005)
Jun 17, 2008 05:24 PM
