knock sensor wire. GSR in an EG 92'
Old Aug 10, 2002 | 03:53 PM
BoM's Avatar
BoM
Default knock sensor wire. GSR in an EG 92'
okay the engine is in and running, since the car is a 92 cx, everything was plug and wired already except the knock sensor right?
where do i access that wire from the engine bay?
and where do i connect that in the ecu?
Old Aug 10, 2002 | 03:56 PM
R_yd's Avatar
Default Re: knock sensor wire. GSR in an EG 92' (BoM)
red/blue wire to d3 at the ecu
Old Aug 10, 2002 | 08:18 PM
Malachi's Avatar
you're IAB wasnt wired either, move a20 to a17
Old Aug 10, 2002 | 11:37 PM
BoM's Avatar
BoM
Default Re: knock sensor wire. GSR in an EG 92' (Malachi)
whats iab?
does that have anything to do with idle?
cause im idling like 2-300 below what it used to.
like around 600rpms
Old Aug 11, 2002 | 06:17 AM
Malachi's Avatar
you should be 750+/- 50 for idle, with the IAC disconnected 480+/-50. the IAB is your secondary runners in the intake manifold. they open at 5500 rpm to give you more topend power.
Old Aug 11, 2002 | 11:44 AM
R_yd's Avatar
whats iab?
like around 600rpms
tell me everything you've done so far w/ the wiring... you might be missing some things.
Old Aug 11, 2002 | 07:15 PM
BoM's Avatar
BoM
Default Re: knock sensor wire. GSR in an EG 92' (Rspool)
this is what i've done
again its a 92 cx with 95 obd1 gsr engine
i pluged all the harness and plugged in the ecu
thats it.
hhaha, i haven't had time to wire the iab or knock.
Old Aug 11, 2002 | 07:39 PM
R_yd's Avatar
well hurry up so you can kick some tails!!!
Old Aug 11, 2002 | 07:50 PM
BoM's Avatar
BoM
affirmative, fire in the hole!
Old Aug 12, 2002 | 05:22 PM
92SiB18C1's Avatar
I got the same problem. I wired everything according to the post. Moved A20 to A17, red wire to A20, red/blue to D3. But when I drove it, 5500 rpm went by without feeling that VTec kicking in. Is there any way I can test it to see if Vtec came on? I just strip the wire in put it in the slot since I don't have any extra pin. Will it work? Do you know where I can get some pins?
Old Aug 12, 2002 | 08:08 PM
R_yd's Avatar
Default Re: knock sensor wire. GSR in an EG 92' (92SiB18C1)
yup, usually bad contact or no contact at all happens if you just put it in the slot. go to a junkyard, they should have em.
Old Aug 13, 2002 | 08:12 AM
X2BOARD's Avatar
So is the IAB wired into the ECU or what ? I thought there was not wiring (vaccum controlled) I am running a obd2 gsr on an LSVT and am experiencing a similar problem.
When I did not have the vtec connected, the engine would just about stop at 4800 tho... (just for info towards the post)
X2
FastAsleep
Jun 28, 2007 09:40 AM
94hatchvx
May 27, 2007 06:50 PM
Kimbo
Mar 7, 2004 08:33 PM
jlsmi2
Jan 9, 2004 09:05 AM
Malachi
Aug 8, 2002 02:28 PM
