Need some help with TIG with pipe
Old Feb 24, 2009 | 05:26 PM
E-Rok's Avatar
EPIC TUNING
Default Need some help with TIG with pipe
Ok I got my fillet welds down pretty good so I tried some pipe. My biggest problem is getting a comfortable position with the torch, no matter what I do it just seems akward. any tips/tricks?
Old Feb 26, 2009 | 05:25 PM
E-Rok's Avatar
EPIC TUNING
Default Re: Need some help with TIG with pipe
anyone?
Old Feb 26, 2009 | 05:46 PM
ToxicFabrication's Avatar
OG Fabricator
i put my pipe in a flat table top vise but dont clamp it. and rest my hand on the edge of the table and go about half inch, turn the pipe and continue
Old Feb 26, 2009 | 06:10 PM
boostedcivicsir's Avatar
Mr. Badwrench
vise grip chain clamp. i havent gotten to pipe with tig yet, but using a chain clamp while stick welding to post up, makes it a little easier.
once i get my damn overhead done ill be on pipe. again he hee.
Old Feb 26, 2009 | 06:29 PM
downest's Avatar
I kind of lay it on/in a clamp or something on the table, whatever is lying around. How are you holding the torch? Do you always wear gloves? Sometimes I hold the top closer to the cup and it's harder to rest your hand on something, I can see having trouble with that (I also don't have very steady hands normally). I also don't generally wear gloves, so I can't really rest my hand on the piece or get it too close. I have had some days when I just can't do it, and some days when I get on a roll and kind roll the pipe over as I weld and don't have to stop so much.
Old Feb 26, 2009 | 07:46 PM
90blackcrx's Avatar
Big tip, get comfortable, lay out on the table if you have to. The key is also to support your arm, or wrist, there really is no other secret.
Get comfortable
Support wrist and arm
Rotate wrist as far as you can around the pipe
Old Feb 26, 2009 | 08:40 PM
DESTROYER's Avatar
hate to say it... practice
Old Feb 27, 2009 | 04:23 PM
NeKe1point0's Avatar
We just got a variable speed welding turntable at our shop. I havent had a chance to use it yet...
Old Feb 27, 2009 | 05:51 PM
E-Rok's Avatar
EPIC TUNING
I forgot to add that I am practicing all positions 1g, 2g, 5g, 6g so I would like to not lay it on the table and roll it. thanks for the input so far tho
Old Feb 27, 2009 | 09:26 PM
GT35R_EF's Avatar
Make mine whatever you want
when ur doin the 5g and 6g its helpfull to use a like a pair of vice grips that u clamp to something els or use something to steady your hand, when i do any pipe welding i always use something to brace my hand on, then as i go around i will keep re-pisitioning it as i go so that i always have a stable place to rest my torch hand.
Old Feb 28, 2009 | 02:15 AM
ROTARY's Avatar
yup, that awkward feeling will only go away with practice.. like learning to eat with chopsticks
if my hands are shaky from drinking energy drinks or coffee i throw on a kevlar glove hold the torch at the head and lightly rest my pinky on work piece, works really well.
Old Feb 28, 2009 | 05:53 AM
E-Rok's Avatar
EPIC TUNING
I remember seeing someone who was testing at my class doing that, ill give that a try thanks
Old Feb 28, 2009 | 11:48 AM
ManBearPig4silly's Avatar
walking the cup on a fillet is stupid easy. Can I explain it with words though? Hell no. Anyone want to give it a try? Better yet someone make a video of it. It's 10 times easier than walking on a butt weld.
You can skid the cup over your weld to help steady your hand on your butt welds until you can figure out how to walk the cup. It's pretty straight forward. Stick your tungsten out 3/16-1/4 lay the back edge of your cup on the pipe and just slide it along while you STUFF filler into the puddle. Don't be a pansy and dab it.
Old Feb 28, 2009 | 02:04 PM
Bailhatch's Avatar
Old Mar 1, 2009 | 08:30 AM
DESTROYER's Avatar
lol so true... dabbing is a time waster
Old Mar 1, 2009 | 08:54 AM
shortyz21's Avatar
agreed. i keep my filler wire in the puddle all the time.
dont use that skinny filler wire **** either, use 3/32
eclypzex
Welding / Fabrication
Dec 20, 2008 09:05 AM
stillsmokey
Dec 28, 2007 12:37 PM
r0yal
Apr 19, 2006 07:03 PM
FURACERMAN
Jan 6, 2006 06:32 PM
tonezilla
Feb 15, 2005 07:17 AM
