b20 vtec
Old Feb 24, 2009 | 03:19 PM
meric0786's Avatar
Default b20 vtec
ok so my friend just put an obdo vtec b16 head on his b20 no vtec engagement at all now i know his coolant temp sensor is broken and he is using a p28 not chipped the p28 should still engage the vtec but only to the single cam redline? also vtec does not engage when the coolant tem is not hooked up? another question is what should the timing be set up at for b20vtec with type r cams and what should his fuel preasure be set atalso how do i set his fuel preasure do i remove the vacume line and setat idel
Old Feb 24, 2009 | 03:37 PM
Ls_dx's Avatar
Default Re: b20 vtec
Coolant temp is a check that the ecu checks for when looking to engage vtak. If the sensor is broken it probably will not crack vtakz. I always set the timing to 16.50 btdc like stock and fuel pressure? 45ish? with the hose off.
Old Feb 26, 2009 | 08:57 AM
meric0786's Avatar
ok apperantly he is throwing a code 16 for the fuel system will this cause no vtec also what is the definition for this code so i know what it is
motormike40
Aug 18, 2010 06:02 PM
DarkVtec EF8
May 9, 2010 05:43 PM
roughneck
Mar 4, 2010 12:35 PM
integraluva04
Jun 18, 2008 05:32 AM
turbo_smallblockchevy
Jun 23, 2005 09:47 PM
