Car wont stay on help please!
Old Feb 24, 2009 | 02:18 PM
Dave_Dc2's Avatar
Default Car wont stay on help please!
i just dropped my my motor in..its a gsr 12.1:1 engine. stock injectors and stock ecu(ob2). if i go to start the car while its cold itll idle fine.but after a while itll just die. why wont it stay on?
Old Feb 24, 2009 | 02:21 PM
Paul1985's Avatar
Default Re: Car wont stay on help please!
Could be a number of things.
I'd check the spark plugs and fuel filter and/or pump as a start personally.
Old Feb 24, 2009 | 02:38 PM
Dave_Dc2's Avatar
fuel pump/filter are brand new.. i used the 250 walbro..and i used irridium spark plugs(pre-gapped)
Old Feb 24, 2009 | 06:32 PM
Dave_Dc2's Avatar
ttt
Old Feb 24, 2009 | 06:35 PM
ruffrhyder's Avatar
Did you swap the tps and iacv sockets by accident. I've seen this happen a few times and cause the car to die.
Old Feb 24, 2009 | 06:57 PM
Dave_Dc2's Avatar
im positive theyre not switched around..bc they were swapped b4 and the car wouldnt even start..i switched em back it it starts now
Old Feb 24, 2009 | 07:00 PM
mar778c's Avatar
Community Builder
Community Influencer
Have you taken the car to be tuned?
Old Feb 24, 2009 | 07:08 PM
Dave_Dc2's Avatar
not yet but the tuners said that wouldnt fix anything..
Old Feb 25, 2009 | 04:28 AM
mar778c's Avatar
Community Builder
Really, you mean adjusting ignition timing, fuel, and IACV duty won't help to fix a car that won't idle.
I guess you learn something new everyday or maybe you should find someone who knows what they are doing.
Old Feb 25, 2009 | 04:35 AM
96b18c-r's Avatar
i just put a type r in my car like a month ago.. i had a similar problem, but not quite the same. Make sure you don't have two of the harness wires crossed into the wrong ones. I had to plugs that are next to eachother in the wrong ones which was a simple error, and then the only other thing was the throttle air control sensor **** was clogged. But the problem i was having was it wouldn't stay on at cold start but if it was warm it would. but as soon as i got the harness right, and cleaned that **** out, ooo and a small vacume leak from the back of the intake manifold where the cruise control use to be hooked up, capped off.. everything worked fine.
Old Feb 25, 2009 | 07:08 AM
Dave_Dc2's Avatar
i totally agree..thats what i was saying..but what they said is that if all the fuel managing is stock..it should be fine. i sure do hope they are wrong and that the tune will resolve this issue.
Old Feb 25, 2009 | 09:47 AM
LaCaNaRacing's Avatar
New User
i have a 98 civic with a b20b and i was running the car with the sohc ecu p2p..and it was running ok, after 2000rpms...so i bought the jumper harness to convert it into obd1 with my p28, which in my case is obd2a. so i plug it in and the car starts but wont idle so it just dies!!!a nunber of things have been changed, tps, map sensor, distributor, ignition module, etc...i tried a p75 i have and it does the same thing..i also messed with the fuel regulator it was 50 so brought it down to 38 thinkin it was runnin to rich...anyone who can help???
Old Feb 25, 2009 | 11:37 AM
ruffrhyder's Avatar
But your fuel delivery isn't stock so how will running a stock ecu with an aftermarket fuel pump and 12:1 CR be fine?
smd4life
11
Sep 1, 2009 05:36 AM
deanBUG
13
Apr 22, 2009 10:33 AM
viprcr1
24
Sep 8, 2006 12:26 PM
Turbo-Honda
Jan 5, 2005 05:08 AM
neo92RS
Jun 5, 2003 11:47 AM
