How F'd is this head?
This is a buddy's head. He had another guy build the motor and I stareted helping after the motor was in.
Ok so the car kept jumping timing so I tore into the head and found this. The 12mm's were torqued to around 20 ft. lbs. I have a snap on digital torque wrench so I used those to take the cams off and it was reading 20 when they broke loose.
Here's the damage. Can it be fixed?
And to make things worse I think there miss matched cam caps. He bought the head used and the guy who built it didn't check. There seems to be a little bit of a ridge where the cams meet the head.
From: New York in the summer, South Carolina in the winter
Dover heads of Greenville SC does line bores for 125 dollars- If a bearing is needed they charge for the bearing itself. So it comes down to the work already done to the head.
In my opinion, I wouldnt run something that an idiot messed around with ya know? Its so easy just to go and find a OEM head never been touched and go from there.
DTRcivic
10
Jun 26, 2004 09:33 AM
JDMvtecDRAGSTA
Apr 18, 2002 12:07 PM
