Main relay?
Old Feb 24, 2009 | 05:18 AM
northemt88's Avatar
Default Main relay?
I just installed a new 255 fuel pump i was just wondering if any of you guys and girls withe these hi flow pumps ever have any problems with your main relay for the fuel.....
Old Feb 24, 2009 | 05:37 AM
digitally_remastered's Avatar
Default Re: Main relay?
as for the main relay, i dont think it will supply enough power to the pump to make use of it. i think you may have to wire it to a 12 volt switch from the battery to get efficient use out of it.
Old Feb 24, 2009 | 05:42 AM
allgo88's Avatar
how about you stop talking. the stock relay is fine for a 255.been daily driving mine for two years.if you do ever have a relay prob,its from the solder separating from the board.it happens over time.re solder it or buy a new one.
Old Feb 24, 2009 | 06:14 AM
yeah did you just replace this for your stock pump on a stock engine? there are different ways about making use of this pump. especially if he goes boost.
Old Feb 24, 2009 | 07:44 AM
allgo88's Avatar
im far from stock.https://honda-tech.com/album.php?albumid=10668 also my my buddy(dc2turbo)is making 450hp on e85 w/1000cc injectors.255 pump.stock relay.
Old Feb 24, 2009 | 07:48 AM
nfereorhatch's Avatar
What the hell? /\ Been using a stock main relay for five years on two different boosted setups with a 255 and NEVER had any problems.
Old Feb 24, 2009 | 08:47 AM
allgo88's Avatar
so have about a million other people.i wish people who dont know-would stop posting false info.it discourages new people,and wastes time and money.back to the subject,your stock relay will be fine.
Old Feb 24, 2009 | 08:53 AM
nuff said!
Old Feb 24, 2009 | 11:49 AM
northemt88's Avatar
thanks allgo88,yeah i think my relay is done for i put in the freezer it worked for about 30 seconds,so ill go get a new one
Old Feb 24, 2009 | 11:57 AM
xalents23's Avatar
Did you see any cracks on the solder on your Main Relay? If you do you can always re-flow the solder joints. Or add new solder. Instead of buying a new main relay.
Old Feb 25, 2009 | 05:05 AM
northemt88's Avatar
how do you open the casing?
Old Feb 25, 2009 | 05:50 AM
~sp33~'s Avatar
EFB055
Im pretty sure mine clipped on.
Old Feb 25, 2009 | 06:07 AM
Snafubmx234's Avatar
Your pump will perform better if you wire a 12v source right from the battery using a relay, but that improvement comes from larger then stock gauge wiring, not the relay.
Old Feb 26, 2009 | 09:46 AM
northemt88's Avatar
so its not really a requirement?
Old Mar 3, 2009 | 05:19 AM
northemt88's Avatar
bump
Old Mar 3, 2009 | 10:36 AM
Targa250R's Avatar
be professional
Just put in a new main relay or re-solder your old one.
You're thinking into this way too much.
Old Mar 3, 2009 | 09:15 PM
240driftkid's Avatar
my car ran good before.. i just installed the same fuel pump, but went to start it and it primed but sounded real loud, then i tried it again and nothin.. now it just cranks, could my main relay have just gone out?
Old Mar 4, 2009 | 04:22 AM
Targa250R's Avatar
be professional
Find out why it isn't priming. Test for power at the fuel pump connector. If you're getting power, the main relay is good and the fuel pump is bad. If you're not getting power, either the main relay is bad or you have some other wiring issue. Do you hear the relay click under the dash?
Old Mar 4, 2009 | 05:57 AM
no it doesnt click, and the cel light stays on.. i'll check it out today
Old Mar 4, 2009 | 09:15 AM
scottmog's Avatar
i installed a walbro 255 and a new oem relay at the same time. about 8 months ago. both are still working fine.
Discontained
Sep 8, 2006 10:13 AM
EG6LS
May 22, 2006 09:30 PM
DnB TeK
Jun 22, 2005 02:46 PM
markvqwerty
Aug 27, 2004 08:52 AM
Steve
Aug 29, 2001 06:38 PM
