eg w/b16 swap wont start
Old Feb 23, 2009 | 03:22 PM
khock3's Avatar
Default eg w/b16 swap wont start
the car started up just fine and on my way home it just died. I am getting spark, i can hear the fuel pump when i turn the key on, but I am not getting any power to the injectors. also the main relay clicking like crazy when i turn the key on. I have already tryed a new relay and that didnt make a difference.
any thoughts?
Old Feb 23, 2009 | 06:51 PM
joelmatt89's Avatar
Default Re: eg w/b16 swap wont start
i had the relay click like that once it was because it wasn't getting enough power from a bad wire check if you are getting 12v to it
Old Feb 23, 2009 | 07:02 PM
Former User's Avatar
Also check whether fuse 24 is loose or whether the Blk/Yel wire terminal in the connector for the main relay is damaged.
Old Mar 1, 2009 | 11:22 AM
khock3's Avatar
it was the ignition switch!
Old Mar 16, 2009 | 09:32 AM
khock3's Avatar
well I was wrong, its not the ignition switch. The reason i thought it was, was because my buddy has the same car and we tried his switch and it worked. then I ordered a new one for my car, put it in and it still is not starting, so I tried my buddies again and now it wont work with his either
i know its not the main relay because I have tried three different relays
so once again, when I turn the key on the fuel primes for a few seconds, then I try to start it and when I turn the engine over the relay clicks like crazy. we put a node on one of the injectors and they are not getting any power.
any other help would be appreciated
perpetualburn
Oct 3, 2020 06:08 AM
D7KWagon
Aug 28, 2014 12:20 PM
JDMPHILEP91
Sep 13, 2009 06:04 PM
efking1985
Feb 13, 2007 03:43 PM
sxecustoms
Jun 11, 2003 07:47 PM
