Car not starting!!!Need Help!!!
From: Where All Funky Things Come From...., Stankonia, USA
Ok so I had just changed my oil and had taken my car out for a drive to make sure everything was find. The car ran like a champ, everything was perfect. I went back to my friends house to pick up my tools. When I started to drive away from my friends house my car bogged down and then turned off. WTF! I tried to get it started but it just wont start. I can hear the motor actually try to start up but it really never gets going. It was kind of late when this happen so I just left it alone for now. What do you guys suggest that I check? Anyone ever have this problem? Suggestions are greatly appreciated.
D16Z6 with Greddy Td04h kit. I had just changed the thermistat and wired my fan to a toggle switch.
Thanks
Thanks
Nice set-up
Check all of the routine maintance stuff and then make sure there is gas, and blah blah blah. And then dig a little deeper. I am thinkin that you already did this though.
It is a possibility that you wired it up wrong.
Check all of the routine maintance stuff and then make sure there is gas, and blah blah blah. And then dig a little deeper. I am thinkin that you already did this though.It is a possibility that you wired it up wrong.
Is it getting any gas?fuel pump come on ? check the fuses? It just sounds like its not getting any gas,cause it cranks right? make sure you didnt blow a fuse when you wired up the switch.
[Modified by eg_nezay, 10:36 PM 8/10/2002]
cleanej2
12
Aug 8, 2007 03:36 PM
Acrappyhatch
Mar 5, 2007 08:24 PM
GO-FIGHT-KILL
Oct 23, 2006 02:01 AM
lude12423
Mar 27, 2005 07:45 AM
