car wont start.. think it mite be dizzy
my car stalled out and i couldnt get it started again till the next day.. my rpms where jumpin around from like 2 to 3.5 really fast .. i stopped and turned my ac on to see if it had any affect and the car stalled out and i havent been able to get it started again
Re: car wont start.. think it mite be dizzy (mustang5.slow)
i dont think its my grounds... the car will crank but it wont turn over
P.s. i checked to see if it was throwing any codes and it would sometimes but not others
Re: car wont start.. think it mite be dizzy (cleanej2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cleanej2 »</TD></TR><TR><TD CLASS="quote">...when i had the car started earlier my fans werent turning on either</TD></TR></TABLE>
Your fan isn't going to turn on unless the car is running and the CTS detects that the water coolant is too high of a temperature. If you're talking about the AC fan that won't turn on until your AC is on (obviously).
As for your problem, it's real simple, it's NOT a ground, I don't know why somebody said that, but if it's turning over, it's not a ground.
2 Steps to diagnose:
1: Check to see that you're getting a spark from all 4 wires.
2: Check your fuel pressure when the pump is primed and you're turning the engine over.
Do both of those, and you can narrow down the problem a lot more efficiently.
Also, check the power output of the battery with a multimeter - is it definitely turning over sufficiently to start the car?
That also eliminates the starter motor.
The problem's probably your igniter, check to see if you're getting a spark first.
Re: car wont start.. think it mite be dizzy (Syndacate)
im pretty sure im getting a spark from all 4 wires b/c i had the car started yesterday and i didnt really have any problems with it until it got up to temperature and then it stalled out when i hit the gas
Re: car wont start.. think it mite be dizzy (ejprimo)
thats what i originally thought too.. would it be something specific in the distributor i could replace instead of the whole thing just b/c im tryin to save a little money for when i go away to school
Marble
02-10-2006 05:18 AM
