Got a d16z6 overheating issue
Old Feb 23, 2009 | 09:55 AM
hondamike89's Avatar
Icon6 Got a d16z6 overheating issue
Ok guys i got a issue. Im thinking my thermostat is stuck closed but im not definite..
So i start my car and everything is normal, i wait like ten minutes come back out and start driving. Temp gauge is reading normal at start. But as soon as i start driving it starts to go up a bit. No problem i was thinking maybe it was just from the motor still warming up. I get going maybe doing like 45 and the gauge just starts rising slowly up. I pull over and it goes back down. I pop the hood. Check the houses. The bottom hose is hot but is collapsing a little. So i pull it into the garage. Let the car cool down about 15 minutes. Take off the bottom hose to see if its blocked up somewhere. Antifreeze goes everywhere! like rushing out without the car started and it cooled down. What do you guys think? Thermostat problem? air in the system? idk what it is help me out
Old Feb 23, 2009 | 09:59 AM
slo_hatch's Avatar
Default Re: Got a d16z6 overheating issue
probably thermostat blocked up...it sounds like you have air in the system. bleed it and see if it helps. also look around for any leaks. i had one hose on the back of the IM that was dripping just barely and it fixed it some, but i think i had air in the system also.
Old Feb 23, 2009 | 10:20 AM
F4MzEkSOL's Avatar
cut the thermostat up and run a fan cause im onli using the thermostat housin lol and its direct flow with the fan coolin it down but its a bitch gettin to warm up lol
Old Feb 23, 2009 | 10:28 AM
slo_hatch's Avatar
you can take the thermostat out and boil it in water and see if it is stuck or if it comes open. my dad used to do it all the time and confused the **** out of me. lol
Old Feb 23, 2009 | 07:44 PM
haha nah. Ill keep my thermostat. I tried burping the coolant system and got nothing. Im thinking it is stuck shut from all my years of honda motor builidng haha. Figures something as simple as cooling always stumps me
The Dirty EJ1
Aug 12, 2006 02:02 AM
s1ngle
Dec 12, 2005 05:26 AM
DEL_SOL_BELLA
Dec 7, 2005 08:36 PM
dcsports
13
May 27, 2004 10:18 AM
ChadTeg
Nov 25, 2003 11:14 AM
