need help h-t !!
need help h-t !!
like a month ago i made a thread bout car overheating ... so i changed my thermostat ... and it look fuked the rubber things on it look like it was being burnt and it was missing alot of rubber on it.... well i put another one in... and it works alittle bit better.... but my fan only goes off when car is jus sitting still and it comes on alot like every 5 mins but when im driving it on the road it doesnt come on... and also the car temp gauge comes up to the middle very quick maybe 5 mins well let me know wats going wrong
leaky headgasket? its a possibility
more than likely tho its either a faulty thermostat. i went through 4 thermostats til i got one that worked decent. or you could have a big air bubble trapped in the system.
Try and blead the coolant system. remove the radiator cap when the car is cold. start the car and put the heat on full blast. and fill up the coolant til it stops bubbling. make sure the engine is warm when its stopped bubbling. also pop your valve colver and check and see if the oil looks different.
Sounds like its time to upgrade that radiator. or if you are strapped for cash u could try thes to suggestions. cost under $5 to do both.
One trick you could do i see you live in maryland and it stays decently warm out there. you could take your thermo stat out. and drill 2 or 3 1/16" holes in the thermostat and that will keep it at a real cool temperature. or you could wire up a manual fan switch
Re: (JDMlifestyle)
yea i am leaking oil from somewhere but its not bad ... i was thinking bout gettin a del sol dual core i dunno wat i should get?
Re: (rocco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocco »</TD></TR><TR><TD CLASS="quote">ib4tl </TD></TR></TABLE>
Re: (JDMlifestyle)
yup i have a/c hmm thanks bro for the nice help i might go buy a new thermostat i took this one i install from a vx motor looked fine
Go to honda to get your stat. here is a thread i did a while back. about thermostats
https://honda-tech.com/zerothread?id=733952
Re: (dcsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcsports »</TD></TR><TR><TD CLASS="quote">
?</TD></TR></TABLE>Im not trying to be a ***** or anything but i think your supposed to be a little more specific with your title
Fighterinsnatch
11
05-21-2007 02:43 PM
