B series swap mounts?
Old Feb 23, 2009 | 07:57 AM
420waipio's Avatar
Default B series swap mounts?
Im kinda short on my swap till i get my taxes back, but just wondering i got some stock motor mounts off of the swap i bought (b18c1) and also have my d15 mounts, which mounts could i use to get it running for now? The swap is a b18c1 goin into a cx hatch.
And also what mounts would be a good aftermarket swap mounts? Hasport?
Thanx!
Old Feb 23, 2009 | 09:12 AM
MeyekulBayrd's Avatar
Default Re: B series swap mounts?
You're going to have to buy mounts. Pick up some innovative mounts, the black ones are under 300 bucks.
Old Feb 23, 2009 | 09:15 AM
HiProfile's Avatar
A 92-95 hatch should use the 5 mounts that came on the B18C1.
It depends on what you want from the swap for mount choice. I'd only get aftermarket mounts if: 1) I was going to race it w/nitrous or turbo, 2) the stock mounts are completely shot, 3) I have some fillings I need removed (from the vibration). For something that isn't a dedicated track car, I'd just get the Energy Suspension inserts. The kit usually covers the rear mount and front torque mounts, and eliminates almost all motor movement, without the bone-shaking vibration.
00GSREJ8's Avatar
or if you know some one with stock Si mounts from a 1999 2000 they will work but you need the bracket off the driverside of the motor as well...umm never mind wrong body style
Old Feb 23, 2009 | 09:22 AM
The 99-00 Si shift linkage would work as well; but yeah, wrong body style. I'd want poly mounts.
Old Feb 23, 2009 | 09:46 AM
slo_hatch's Avatar
you can use all the mounts off of a 94-01 teg...except maybe the banana mount in the back. but the rest should work. same with shift linkage...use integra linkages. so if you have the b18c1 mounts...that should work. i may be wrong about the torque mounts...but main mounts will work.
dwils
14
Apr 21, 2011 02:00 PM
D16SohcVtec
Aug 12, 2008 08:03 AM
integrawow
May 23, 2007 11:16 AM
pauld
Feb 18, 2007 06:20 AM
