car sitting crooked!! but WHY?!?!
Old Aug 10, 2002 | 08:47 AM
nicksweetlude's Avatar
Default car sitting crooked!! but WHY?!?!
i just installed those kyb agx struts and eibach pro kit springs. and the drivers front is really low compared to the others, and the passenger rear is a little high, but the other 2 are ok. so what could be the problem? i did them all exactly the same. im baffled.
Old Aug 10, 2002 | 11:49 AM
Chiovnidca's Avatar
Default Re: car sitting crooked!! but WHY?!?! (nicksweetlude)
Are you sure you didn't get the springs mixed up? Did you put a rear spring on the front, and vice versa?
Old Aug 12, 2002 | 07:29 PM
Default Re: car sitting crooked!! but WHY?!?! (Chiovnidca)
im absolutely positive. 100% sure. what else could it be?
Old Aug 12, 2002 | 08:01 PM
Import RP's Avatar
My car did the same thing. It wasn't THAT bad, but different parts looked lower and higher. Now, they all look the same. I think you need to give the springs a chance to settle (try 2 weeks) before you start worrying about that kind of stuff.
Old Aug 13, 2002 | 11:18 AM
PrecisionH23a's Avatar
yes the springs need to set. also, did you install the rubber bushing that goes on the top of the spring? you might have left it off on one side throwing the height off.
Old Aug 13, 2002 | 04:52 PM
Default Re: car sitting crooked!! but WHY?!?! (GudeH23a)
maybe it will settle. i hope it does. its only been a week. so maybe with some luck things will work out. thanks for your help
rekreb38
Suspension & Brakes
Nov 3, 2010 10:30 AM
docbrown
Suspension & Brakes
Jun 19, 2009 07:22 PM
david itr
Feb 17, 2008 06:27 AM
BlueRex1020
Feb 9, 2007 04:43 PM
b18bme
61
Jul 5, 2004 07:23 AM
