when replacing cam seals, do you use silicone?
Old Feb 22, 2009 | 12:32 PM
averyvm's Avatar
Default when replacing cam seals, do you use silicone?
Hey what up HT,
I got a stock LS motor and I have a strong feeling the camshaft seals are leaking. When installing the new ones should I go ahead apply silicone onto the new camshaft seal? What do you guys normally do? Thanks
-Avery
Old Feb 22, 2009 | 12:36 PM
AnDThEnWuT's Avatar
Default Re: when replacing cam seals, do you use silicone?
I usually put a nice thin layer evenly around the seal.
Old Feb 22, 2009 | 03:36 PM
dvs94Teg's Avatar
From: NORCAL Salinas Valley to Monterey Bay Area 831 CA
id try hondabond.
Old Feb 22, 2009 | 04:07 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Never used any kind of sealant with camshaft seals, and never had any problems with leaks. I've changed them twice on my car.
You DO need to use HondaBond or Permatex Ultra-Grey on the right-angle corners of the valve cover gasket. Do NOT use silicone!
Old Feb 22, 2009 | 06:26 PM
dvs94Teg's Avatar
Originally Posted by averyvm
hey what up ht,
i got a stock ls motor and i have a strong feeling the camshaft seals are leaking. When installing the new ones should i go ahead apply silicone onto the new camshaft seal? What do you guys normally do? Thanks
-avery
hondabond!
Old Feb 22, 2009 | 11:33 PM
TheHypnotic's Avatar
+1 I used a few dabs around the cam caps.
xxilah7861
Mar 15, 2015 05:42 AM
Groove_D
Feb 26, 2006 06:15 PM
sinister357
Aug 29, 2005 09:47 PM
1.7na
Jan 23, 2003 12:20 PM
four27
Jan 25, 2002 02:54 PM
