does increasing your oil pressure = more power
Old Feb 22, 2009 | 10:19 AM
eg:R's Avatar
Post does increasing your oil pressure = more power
as title, ive heard that having more oil pressure can help increase power. like modified oil pump, plugging oil squirter, taking out balance shaft and ect... wondering if this is true. but on the other hand i will read posts of some people worrying about having too much oil pressure and that it can cause engine damage.
Old Feb 22, 2009 | 10:27 AM
slammedem1's Avatar
Default Re: does increasing your oil pressure = more power
not too sure if it adds power but you shouldnt remove your oil squirters unless you have forged internals.. im sure alot of things arent recommended but im not certain..
Old Feb 22, 2009 | 10:37 AM
Andr3w's Avatar
Im sorry but in my entire life ive never herd such a dumb question ever...ever!
Whoever told you this got it off the base that less friction = more power. but thats now the way of doing things. You only usualy more more oil pressure to not starve your internals when reving high. etc.
Old Feb 22, 2009 | 11:41 AM
B20luda's Avatar
to much pressure could result in rupturing your oil filter, having more oil pressure wont result in more power, if anything it would make you lose power..
Stock oil pump with no balance shafts or oil squirters is just fine, no need for anything more to increase oil pressure. a properly clearanced engine is much more important.
Old Feb 22, 2009 | 12:37 PM
SovXietday's Avatar
Something to take from this.
When you hear "rumors" written "lik dis" they're probably about as dumb as the person saying it.
Old Feb 22, 2009 | 12:55 PM
bigD's Avatar
you need one of these http://kalecoauto.com/index.php?main...&products_id=8
Old Feb 22, 2009 | 01:26 PM
eg:R's Avatar
why is Stock oil pump with no balance shafts or oil squirters is just fine to do but no need for anything more. so your saying its good to increase your oil pressure?? why would you say that when you stated that having more oil pressure wont result in power and will make you lose power. why will people do this if it will make you lose power.
i remember searching for the oil squirter plugs and saw a note on that side saying that "it will help engines with vtec". why would they say that when only vtec motor came with oil squirter. i wonder why people would do these modified if there wasnt any gain. unless there is somewhere
Old Feb 22, 2009 | 01:47 PM
Flashmn's Avatar
People do alot of stupid things, because of unfounded rumours. These then spread like wildfire becoming truths.
Old Feb 22, 2009 | 01:48 PM
Ls_dx's Avatar
Just run your Stock oil pump and forget about it!
Old Feb 22, 2009 | 08:48 PM
Scott_Tucker's Avatar
Although increasing pressure could burst the body of the filter, oil filters have a bypass valve which opens at a relatively low pressure (~10 psi) and sends unfiltered oil past the filter element and into the engine. Only 10 - 20% of oil is filtered on one pass. Just FYI.
Oh, and no, increasing oil pressure will not result in any power increase and will probably result in less power because of the extra power required to drive the oil pump.
Old Feb 22, 2009 | 08:50 PM
BMo Tuning's Avatar
STAR
no god dammit
Old Feb 22, 2009 | 09:13 PM
B20luda's Avatar
People remove the balance shafts for mutiple reasons, if you cant figure out why, its pointless to try and debate this.
Old Feb 23, 2009 | 07:19 AM
SovXietday's Avatar
Most of the time they are not done for gains, they are done for safety reasons.
For instance. The Y7 and Y8 Dseries engines are notorious for having low oil pressure and spinning rod bearings. So people will shim and port the oil pumps to move a bigger volume of oil in order to keep a built engine spinning at 8000+ rpms from spinning a bearing.
an2ny888
May 6, 2013 10:31 AM
fr3dy_1
17
May 23, 2008 11:33 PM
hondapwr
Mar 11, 2004 02:43 PM
vtec.dc2
Feb 1, 2004 10:49 AM
toooslow
Oct 19, 2003 04:05 PM
