damn trouble codes
Old Feb 21, 2009 | 07:30 PM
kevodean's Avatar
Default damn trouble codes
havent had a single problem in atleast 3 months...
alright so my speedometer randomely turns off, then on
then my check engine light turns on and my d4 starts flashing
i pull over and restart...nothing, go home, ran codes
17 comes up, means vss (vehicle speed sensor[why is d4 flashing then?])
Old Feb 21, 2009 | 07:38 PM
redbull-1's Avatar
Default Re: damn trouble codes
You can read more about why here:
http://techauto.awardspace.com/vss.html
Old Feb 21, 2009 | 07:56 PM
Targa250R's Avatar
be professional
What year and model?
Old Feb 22, 2009 | 06:05 AM
kevodean's Avatar
1994 honda accord ex sedan...f22b1 vtec
Old Feb 22, 2009 | 06:49 AM
Targa250R's Avatar
be professional
Check the plug on the VSS in the transmission.
Old Feb 22, 2009 | 08:35 AM
Turbowa's Avatar
Its either going to be your speen sensor in the tranny or the speedo head. More then likely its the speed sensor due to the d4 light blinking.
Old Feb 22, 2009 | 09:30 AM
kevodean's Avatar
okay...but what am i looking for? i have alot of my passenger side parts out like intake and some vtec stuff bc im changing seals but seriously ive never even see a vss, i knew there was something like that but to tell you the truth i thought a vehicle speed sensor was on the wheel or something wierd like that, had no idea it was on the tranny...is it going to be broken? unplugged? gone? lol ive ran into problems where i was looking for something that just wasnt there bc it broke off (vtec sensor)
Old Feb 22, 2009 | 09:34 AM
GhostAccord's Avatar
The link posted above shows you what your looking for.
Old Feb 22, 2009 | 09:55 AM
kevodean's Avatar
alright, i found the vss...it was easy to tell what the problem happens to be. i have an oil leak coming from my vtec oil pressure switch and it was running straight down to the vss, the plug has oil all on it, can motor oil ruin this plug? if so where in the **** am i to get just the plug, the male part with the wire
Old Feb 22, 2009 | 09:59 AM
Targa250R's Avatar
be professional
Try cleaning up the plug (not the sensor) with some brake parts cleaner or carb cleaner to remove the oil.
redbull-1's Avatar
You may not have to replace the plug. Get some brake cleaner or electrical contact cleaner and try to clean it first.
Old Feb 22, 2009 | 06:51 PM
kevodean's Avatar
did all of that, ill see if it works tomorrow...had work so i was sidetracked
janelectric
Aug 27, 2012 06:04 AM
DC2man
Mar 3, 2008 07:01 PM
98IntegraLSNonVtec
Dec 24, 2005 11:52 AM
shaveman
Aug 7, 2005 03:37 AM
