crx main relay
Old Feb 21, 2009 | 12:43 PM
spencerxfr3sh's Avatar
Default crx main relay
i just put in a main relay and my car ran fine for a week fine now when i start it it kinda bogs then it dies i think that the relay keeps on going out what is causing that? if anyone could help i would appreciate it
Old Feb 21, 2009 | 03:57 PM
shaggyeg6si's Avatar
Default Re: crx main relay
I honestly don't think its the relay. If its new, there won't be degradation in performance, it literally just turns things on. Probably a failing fuel pump.
Old Feb 21, 2009 | 06:36 PM
its not new i got it frm the junkyard and it was running until the next morning and my battery keeps on drainin gbut im charging the battery right now to c. im gonna try and buy a brand new relay
Old Feb 22, 2009 | 08:47 PM
Jnote's Avatar
before u buy a new relay have your altenator tested especially if its draining your battery
Old Feb 23, 2009 | 08:36 AM
Lanolin18's Avatar
Its possible for the relay you got to be trash based on how many go bad.. I would try a new one or a buddies known working one to narrow it down.
Old Feb 23, 2009 | 09:00 AM
+2 for that guy^
The main relay is a box with 3 relays inside. If one of them goes bad, it could make a permanent connection causing whatever that specific relay controls to be on all the time.
Pull the alternator and take it to pep boys or advance, they test them for free.
Old Feb 23, 2009 | 12:48 PM
detuned's Avatar
if you're still worried about the relay, do the solder trick. it's in the FAQ. works like a charm.
Old Feb 23, 2009 | 01:56 PM
thanks ima go try and pull the alternator incase also. ill update on what is going on
Old Feb 23, 2009 | 02:58 PM
k i soldered the relay and starts up perfect but then the car bogs when i gas it and then dies????
Old Feb 23, 2009 | 05:42 PM
jimihendrixbro's Avatar
Check your spark plugs and your fuel pump. Have you done an ignition check-up? (New cap, rotor, plugs, wires) Could be something there.
-Jake
pyroom
12
Apr 6, 2025 10:42 AM
Ahknodd
38
Jul 7, 2024 04:49 PM
batvrdy
Oct 10, 2018 12:50 PM
DirtyDA9
Jan 27, 2012 11:38 AM
Carbcivic
Oct 14, 2005 11:10 AM
