Hunting Idle with no CEL
Old Feb 21, 2009 | 08:35 AM
Powelly's Avatar
Default Hunting Idle with no CEL
So I decided to get the civic out the garage only to be greeted with a hunting idle. It's showing no cels and I've checked for any vac leaks which I found none, I know the knock sensor is broken but this was turned off when the car was tuned so I can't see this suddenly being my hunting problem.
Am at a loss what to check next as i'm getting no codes
Any ideas? It's a Civic SiR
Thanks
Old Feb 21, 2009 | 08:39 AM
Former User's Avatar
Default Re: Hunting Idle with no CEL
What year Civic? If it has a FITV, clean that and also the IACV. Also try topping off and bleeding the cooling system.
Old Feb 21, 2009 | 10:20 AM
Powelly's Avatar
It's a 93. I haven't messed with the IACV so wonder why it's playing up all of a sudden. The heating is working fine and it's not overheating.
Old Feb 21, 2009 | 10:53 AM
Originally Posted by Powelly
...The heating is working fine and it's not overheating.
You may have some air trapped in the cooling system that is causing the hunting idle. This would not necessarily cause an overheating or heater problem.
Also try cleaning the FITV:
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/
Old Feb 21, 2009 | 11:15 AM
joelmatt89's Avatar
ive got a similiar problem with what and how can i clean the iacv do you have a good link for that as well
Old Feb 21, 2009 | 11:51 AM
Check here:
http://www.hondacivicforum.com/forum...ad.php?t=62836
Old Feb 21, 2009 | 12:17 PM
Powelly's Avatar
Thanks for the info guys, i've been searching about and it seems to be a common problem really.
Will give them both the IACV and FITV a good clean and check for air in the coolant.
mannyquestions9
Sep 29, 2024 09:15 AM
DumpedSi
Jul 26, 2012 05:26 PM
Davidkak
May 2, 2010 11:21 AM
the.hamburglar
May 10, 2007 08:46 PM
animal_si
May 3, 2006 04:32 AM
