95 gsr wont start, please help thank you
Old Feb 21, 2009 | 07:49 AM
eg2GAMEOVER's Avatar
New User
Icon6 95 gsr wont start, please help thank you
what happen was, i was driving on the freeway on my way home and the car just turned off on me. i changed the distributor but the car gets spark. changed the fuel pump and still same problem. it cranks over but doesnt start up. im not really sure but would the injectors have some type of clogging if there is fuel but it wont start up.and i also replaced the main relay. can anyone give me a suggestion on what else to try
Old Feb 22, 2009 | 07:16 AM
Dlamazing's Avatar
Default Re: 95 gsr wont start, please help thank you
timing belt jumped? check timing and compression
Old Feb 22, 2009 | 07:27 AM
Micha's Avatar
FAILWGN
Damn. Never mind.
Check your timing belt.
And also all your fuses.
Old Feb 22, 2009 | 07:31 AM
bigcivman09's Avatar
maybe your main relay is going bad?? tap on it a few times while you try to crank it over.
Old Feb 22, 2009 | 07:33 AM
Micha's Avatar
FAILWGN
He said that he changed it in his first post.
Old Feb 22, 2009 | 08:55 AM
all i didnt see that, my buddy had a 95 gsr it shut off all the time for no reason and his
02 sensor was groundin or shortin out something along them lines and he welded it up and it was fine after that..
Old Feb 22, 2009 | 03:41 PM
runninclean's Avatar
check your o2 sensor your injectors might be bad had a similer problem on my buddys gsr check your tensioner if not im lost.
spooledex
Aug 3, 2009 08:27 AM
jasko97
Sep 1, 2008 07:36 AM
boobie1721
10
Dec 18, 2007 03:56 AM
djtsmith007
Aug 20, 2007 08:57 PM
onepoint-gsr
Feb 19, 2006 08:54 PM
