Suspension Techniques Sway bars
Old Feb 21, 2009 | 02:59 AM
immajackuup's Avatar
Default Suspension Techniques Sway bars
well h-t wont ****en let me search on things here so i made my own thread.
what is the correct way to drill a hole for the rear st sway bar?
Old Feb 21, 2009 | 03:57 AM
iliv2xlr8's Avatar
Default Re: Suspension Techniques Sway bars
I would recommend swapping lower control arms with a 94-01 Integra. They are identical except they have the holes for a sway bar. They can be had for cheap, and much easier and safer than drilling.
Old Feb 21, 2009 | 05:01 AM
st dont use the lca,they have a bracket that goes to the shock mount.
i'm talking about putting a hole in the suframe.
Old Apr 21, 2009 | 12:17 PM
worx's Avatar
i need to find this out to
Old Apr 21, 2009 | 04:28 PM
JNocon's Avatar
Here's how mine look w/ the ST sway bar connected to the rear subframe, and the end link is connected to the bottom shock mount.
With GS-R LCA's.
Aftermarket LCA's.
Old Apr 22, 2009 | 11:22 AM
worx's Avatar
nice does the sheet work as a brace? also my sway bar came with a bracket thing bolted to the bushings
Old Apr 22, 2009 | 11:49 AM
JNocon's Avatar
Yup, yup! If your sway bar looks like mine, than you shouldn't have N E problem bolting it up. Where ever the holes on your bracket will be attach to on your rear subframe, then you should drill the same exact hole that the bracket have. Good luck on your built. Lemme see some pics.
Old Apr 22, 2009 | 11:54 AM
FearTheH's Avatar
Aftermarket LCA's.
what kind of LCA's are those? theyre sexy!
Old Apr 22, 2009 | 12:01 PM
JNocon's Avatar
^^^they're called Miusta Engineering, Inc. It's custom fab. and I custom painted the inner arms w/ red anodized paint from Dupli-Color.
Old Apr 22, 2009 | 12:25 PM
FearTheH's Avatar
looks good man, "mad props!" too bad only a couple people will notice them
hatch92civic
11
Dec 28, 2009 06:43 AM
JMelt4
18
Apr 30, 2007 07:43 PM
trrbl1bmx
Suspension & Brakes
Jun 30, 2006 10:51 PM
Nextelbuddy
Apr 1, 2004 01:18 PM
HondaIntegraLS
Mar 8, 2002 01:35 PM
