Front sway bar question.
How do I mount the sway to the chasis on a 93 civic that did not have a factory bar from the factory. I have the Integra front 24mm bar, brackets, endlinks, and front lower control arms. I see most kits like suspension tech come with pieces you need to mount to the chasis and then mount the bar to that. Do I need that? If so where would I get it. I am trying to stay all OEM in the front suspension.
Re: Front sway bar question. (HondaCivicCx)
on the front lca, there is a small hole that would be parrelel to the ground, the endlink goes through that hole and the sway bar is connected to the endlink. There are d bushings and brackets that go around the sway bar, the d bracket surrounds the d bushing. The d bushing is then bolted to the bottom of the car with 2 12mm bolts.
Re: Front sway bar question. (Robster)
I know about the hole in the control arm, but the under side doesn't look like my integra where it mounts to the chasis (one the car itself)
Thanks
Mike
Thanks
Mike
immajackuup
04-22-2009 12:25 PM
JMelt4
18
04-30-2007 07:43 PM
