chop saw blades???
would this kind of blade cut sch10 304 ss and last long? i just got a new chop saw just for collectors and would like to know what a all around good blades is for it that will last a long time.
thanks
heres the link-
http://cgi.ebay.com/ws/eBayISAPI.dll...m=250377115063
thanks
heres the link-
That's a blade for the chainsaw type chop saws.
http://www.stihl.ca/images/prodShots/CutQuiks/TS700.jpg
Electric chope saws like you have and gas chope saws use different arbor sizes (ie the hole in the middle of the blade is a different size).
Make sure you get a blade for a saw with a 1"/25mm arbor.
The blade you posted does look like it is for a gas saw, but he didn't post the arbor size that I could see.
Unfortunately in general chop saw blades don't last long on stainless- at least they are cheap.
Toxic, two people just said that the blade u posted doesn't look like it's for an electric chopsaw... Just get a regular abrasive disc.. Ud be better off trust me.. When those teeth bite, they bite hard and they WILL throw whatever you're cutting 20ft across the room.
Not to be a dick but damn man, fabricators are known for using their unique ability to be artistic. Fab is art, set a path for yourself and let your imagination take the rest. Anything will work, but some are less time consuming then others
Usually if you get a blade that lasts you will have one that also cuts slowly and puts allot of heat into the part and also uses more power. I have found that for a 14 chop saw I use only 3/32 .105 wide blades. If the blades don't wear they tend to load up. The 1/8 or wider blade are usually easier to get but they aren't the best for these saws. The makita blades work pretty good and are thin. but I am sure you can find them at mcs or mcmaster or numerous other places if you look hard enough
this forum was great till FredC joined... so whos using a chop saw for collectors and what blade do you use? i dont want to waste 85-240$ on a blade and its wrong. as for the abrasive disc they dont work for ****, they slowly walk off the pipe
But, abrasive discs are what chop saws use.
If you are talking about a toothed carbide blade like I use, you can't put those in a standard chopsaw that turns 5000rpm, you need an actual dry cut saw that is geared to 1200rpm.
hmmm, makes sense. so you cant use a chop saw meant for metal with one of the carbide blades?
So anyone know off hand what the good deal in dry-cut saws is? I think that might be more what I'm interested in at the moment than a band saw (and it is on topic with this thread, for the most part anyway! LOL.)
This looks kind of sweet:
http://cgi.ebay.com/Milwaukee-6190-1...2em118Q2el1247
Seems like maybe they don't come with a blade, and you have to add at least this much cost to the equation:
http://www.amazon.com/Hitachi-320056...D1P05ZX5WVMDQT
Alright, so has anyone tried gearing down a Harbor Freight chop saw? LOL! ! !
I will go on the limb here and say you can rig up a milwaukee portable bandsaw as a small vertical and do some pretty handy stuff with it if you can't afford a full size. I will also say that ARA at bullish racing has a like new enco vert for sale. That is LODI,NJ .
.RTErnie
Welding / Fabrication
26
Mar 30, 2006 10:46 AM
