Need help with 00 Si seats!!!!!!!!!!!
Old Feb 20, 2009 | 07:32 PM
chero112's Avatar
Icon2 Need help with 00 Si seats!!!!!!!!!!!
I'm in the middle of swapping out my Del sol seats for a mint set of Si.... I Installed the passanger side, (done easy swapping out rails).... Here is my problem, The driver side of the si seats have these to ***** that adjust the seats to different position..(up,down and so on) How Do I remove these ***** with out braking them? I tried searching, I've been searching for hours. I'm stuck here.... Someone help me out...
Old Feb 20, 2009 | 08:26 PM
chero112's Avatar
Default Re: Need help with 00 Si seats!!!!!!!!!!!
here are some pic's of the ***** I was talking about
Old Feb 20, 2009 | 10:04 PM
chero112's Avatar
come on someone help me out....
Old Feb 20, 2009 | 10:16 PM
devney's Avatar
Do they not fit in your del sol with the ***** or what?
Old Feb 20, 2009 | 10:24 PM
chero112's Avatar
I need to remove the rails, so I can swich them with the ones from the del sol seats... I cant remove the rails because I can't get those 2 ***** off..........
Old Feb 21, 2009 | 06:46 AM
chero112's Avatar
someone help!
Old Feb 21, 2009 | 07:14 AM
devney's Avatar
Just going to have to mess around with them. I'm sure most people don't know how to take them off.
Old Feb 21, 2009 | 07:37 AM
Deetz's Avatar
Crazy Honda Guy
They "pull" off man
Old Feb 21, 2009 | 07:38 AM
chero112's Avatar
I'm sure someone removed them before...... I can get them off , its just that I don't want to break it....
Old Feb 21, 2009 | 07:47 AM
slowa$$ek's Avatar
they are sopposed to pull off. just try and wiggle them around a bit and see where it takes you
Old Feb 21, 2009 | 07:49 AM
95vxtealhatch's Avatar
try prying with a flatbar, or knife?
Old Feb 21, 2009 | 07:52 AM
chero112's Avatar
I was doing that and the plastic started to crack....
Old Feb 21, 2009 | 07:53 AM
chero112's Avatar
I'm going to try it againg....be back in a few..
Old Feb 21, 2009 | 07:59 AM
tha_badguy's Avatar
Are you sure you have to remove the outside rail too?
On civics you just replace the inside rail & they line up after that.
Old Feb 21, 2009 | 12:09 PM
chero112's Avatar
Okay.. first thing is that is does not pull right out... You have to push the bottem part of the seat as far as you can because there is a clip and the end of the ****.. It tock three people the get this done.. it was a pain in the a. s. s..... But I finally got it and installed in the car. The seats look great....
chero112's Avatar
Well I just changed everything over from seat to another. It work for me...
Hybrid94Hatch
Honda Civic (2006 - 2015)
Jul 15, 2011 08:22 PM
HondaheadBigNick
11
Dec 12, 2008 11:22 AM
DomSolDel
Sep 26, 2008 12:44 AM
JSPECHB
10
Jul 21, 2003 01:50 PM
ITR632
May 24, 2002 12:20 AM
