Engine swap? What to or best
Im on a Budget and what motor swap Would be best? I am also new to engine swaps, what components are mainly required? Axles, Trans, ECU, mounts, and ?
Im thinking B20/Allmotor, B16A2, or B18B1 what motors would be cheaper to build and reliable?
For a B20 longblock stock hows is it in preformance wise?
Going V-tec On A B20 what is needed A differ head? whats best?, would it be expensive going to a B20 V-tec Route?
ETC.
Please need sum comments?
ETC.
if you are on a budget, i'd recommend just buying a b16 swap. it's quick and reliable. but yup, just need the motor, tranny, axles, mounts, ecu. and it depends on what car it's going into. obd1 or obd2?
ETC.
ETC.
Well since your new to engine swaps i don't think you need to mess around with a b20 vtec. You want cheap to build and reliable, well the b18b wouldn't be fun enough though its cheap but you really can't build an all motor b18b thats worth a damn, so of your three choices im gonna have to say b16a though im gonna get flamed for saying so...
+1 a b16 would not be bad.with bolt ons and cams it should be pretty decent. its just as fast as a gsr from a roll. when i had a b16 i never lost to a gsr from a roll. all i had was a cai, clutch and a 8lbs flywheel.
if you dont want to go all motor just boost your single cam.
