Tire balance?
Old Feb 20, 2009 | 02:09 PM
jordan_rael_420's Avatar
Default Tire balance?
ok when i get to about 55-60 mph my car starts to shake until about 90 mph then rides smooth.does this mean i need a balance or could it be something else.
Old Feb 20, 2009 | 02:20 PM
HondaVerno's Avatar
Default Re: Tire balance?
check ur tires PSI. it should tell you on the side wall. my ride was doing this after i bought some new tires. i found out i was overinflated by about 10lbs!!! wooooooweeeee lucky they didnt pop!!! i fixed it, and it rides alot better now. OR it could be camber on ur car.
Old Feb 20, 2009 | 02:53 PM
G2IntegraGS's Avatar
Could be your axles. Checking the tire pressure wouldnt hurt either.
Old Feb 20, 2009 | 03:49 PM
gstrudler's Avatar
how about tire wear? shredded tires can also exhibit symptoms like that. and don't forget an alignment either if you haven't had one in a while.
Old Feb 21, 2009 | 06:08 AM
preluderemis's Avatar
its prolly just tire wear or tire pressure as mentionned...4th gen preludes should have 32 psi on all four tires according to honda
__oversea
Jan 12, 2010 07:51 AM
Hiroshima_VTi-S
Aug 1, 2007 02:26 PM
lowRIDAH
12
Jul 26, 2004 03:16 PM
SOHCMAN
Jan 15, 2004 08:11 AM
preluder
Apr 21, 2003 09:19 AM
