boggin down
Old Aug 9, 2002 | 10:06 PM
MI4$DC5's Avatar
Default boggin down
i just installed some 310 RCs in my gsr. i have the compression lowered to 9:1. i also have a fields vtec/fuel controller, hooked up but not turned on. so im running straight off of the obd1 ecu. and when i get on the gas it bogs down in any gear should i lean it out on the fields and if so how much.
Old Aug 11, 2002 | 04:36 PM
GTM's Avatar
GTM
Default Re: boggin down (And-1)
You're drowning your motor. Each application is slightly different. You definitely need to lean out your fuel curve with the Field controller. Test and tune baby...
Old Aug 11, 2002 | 04:41 PM
Quik Chris's Avatar
Default Re: boggin down (GTM)
Where did you get the injectors from? If you use any OBD injectors on a non-OBD car, it will run way rich-- you need a resistor box to run them.
DenzComp
Jun 5, 2007 02:51 PM
USDMMARK
Dec 26, 2003 05:38 PM
Qwikrex
10
Dec 16, 2002 03:57 PM
canuck-mx6
Oct 28, 2002 02:34 PM
