cant find D16zg swap so...
Old Aug 9, 2002 | 09:30 PM
SLowCrx's Avatar
Default cant find D16zg swap so...
Okay my 92CX motor is smoking cause the rings are gone...So ive been looking for a D16z6 swap..and i havent had any kinda luck.. So i found a 93 DX 4door here locally..its got a D15b7 ...Will this work in my 92cx ...Any differences in wiring?? engine mounts???? and will my CX tranny still work with the D15b7?? Are these engines better than the CX as far as reliability..and strength?? will my CX A/C still work on the D15b7 which compressor will i need?? DO i also need to get the DX ecu?? what all will i need from the DX to make it all work...(a list would be nice) ...Thanks
Old Aug 9, 2002 | 09:43 PM
poison's Avatar
Default Re: cant find D16zg swap so... (SLowCrx)
same wiring, no other wiring necessary, i believe u'll need the ecu from the dx, yes the tranny will work, but high redline u might have problems shifting with the gear ratios of the CX tranny. strengh wise it's 102 hp i believe rather than ur whopping 92 hp that can't open a pickle jar
a/c will also work, no mods required, they all use the same compressor for EG a/c's, for EK's there is lil modification but nothing major -- but that doesn't apply so, but
this will be a VERY easy swap for you. plug and play, tighten bolts and time is all it'll cost you
hth
Old Aug 9, 2002 | 09:46 PM
SLowCrx's Avatar
Default Re: cant find D16zg swap so... (poison)
thanks man ...but 92 hp in a CX?? I think its more like 70hp...
Old Aug 10, 2002 | 04:32 AM
EKB18BPR3's Avatar
cx 70hp
vx 92hp
yea go for it...it should drop rite in...anything is better than a cx...or u could do mini-me. and add a ex tranny...ull notice such a difference!
Old Aug 10, 2002 | 10:25 AM
SLowCrx's Avatar
Default Re: cant find D16zg swap so... (dniedacess)
ttt
Old Aug 10, 2002 | 10:55 AM
poison's Avatar
cx 70hp
vx 92hp
oops, well excuuuuse me, i just got so hung up on having so much hp in that motor that i gave it just a lil more props than i should have on twisting the pickle jar
good luck on ur swap man
Old Aug 10, 2002 | 04:40 PM
SLowCrx's Avatar
Ok so all I need is the engine and wiring harness and ecu everything else i can get from my CX right...?Are you sure the CX ecu wont work with the DX engine...ive been told it will...?? Thanks
Old Aug 10, 2002 | 10:50 PM
SLowCrx's Avatar
any thing else i will need??
Old Aug 10, 2002 | 10:55 PM
Downey's Avatar
theres a guy on here in SF who has a D16Z6 with tranny for sale. Check the classifieds, cant be more than $450.
Old Aug 11, 2002 | 10:09 AM
SLowCrx's Avatar
Default Re: cant find D16zg swap so... (Downeybear11)
Are the engine mount the same on a d15b7 and d15b8...Meaning can i take off my CX mounts and use them on the DX engine?? Is the gear ratios in the CX tranny much Different from the DX?? Will my CX ecu work on the DX engine?? Thanks...
Old Aug 11, 2002 | 05:13 PM
SLowCrx's Avatar
ttt
Old Aug 11, 2002 | 06:50 PM
PhuckinHondas's Avatar
Hey im getting my swap in about 2 weeks ill sell you my d16z6 i live in Los Angeles
let me know
Old Aug 12, 2002 | 05:57 AM
SLowCrx's Avatar
Default Re: cant find D16zg swap so... (In The 16s)
Is my CX alternator still gonna work on the DX or am i gonna have to change brackets?? Is the DX tranny much different than the CX tranny?thanks..
Old Aug 12, 2002 | 06:45 AM
F.U.'s Avatar
hey i have a d16z6 Sohc vtec swap. MAybe for the right price i will sell it I am looking to get rid of it so email me and let me know. I also need to know where you live I am from NJ so. Let me know
wernhersey
14
May 5, 2007 11:35 AM
SDT Project EF
51
Jan 31, 2005 12:09 AM
BadEH2
Jan 24, 2005 07:31 PM
SLOAZZ95
10
Nov 18, 2004 03:13 PM
