ckf bypass trick
Old Feb 20, 2009 | 12:32 AM
sevenfc's Avatar
Default ckf bypass trick
has anyone ever succeeded in this trick...i currently just got an lsv on my 00 ek and still is using an obd2b ecu..do u guys kno the symptoms with not having the CKF trick because im wondering if i should do this also...the problem with my motor is that after awhile of not starting it..it will idle low and sometimes die till i give it some gas to warm up and itll keep its regular idle...the motor was just recently rebuilt meaning still breaking it in..could that be the problem or do i need to do the CKF bypass trick...anyone help pls...
Old Feb 20, 2009 | 10:38 AM
sevenfc's Avatar
Default Re: ckf bypass trick
anybody..
Old Feb 20, 2009 | 12:53 PM
sevenfc's Avatar
help....
Old Feb 20, 2009 | 12:56 PM
biostarled's Avatar
check your main engine relay at high or low idle at start up usualy the solder in the main engine relay is cracked or corroded. you can take it out. pop off the cap from the base aand resolder the conections this should work great for the problem you have explained
Old Feb 20, 2009 | 01:12 PM
94EG8's Avatar
Seagull Management
If you don't have a CKF sensor then yeah you'll have to preform the CKF fix, if you're running an OBD2 oil pump with the CKF sensor then no.
Old Feb 20, 2009 | 02:12 PM
ekb16's Avatar
i did the trick to mine and it works
Old Feb 20, 2009 | 02:19 PM
biostarled's Avatar
the relay trick?
Old Feb 20, 2009 | 04:25 PM
Redbone's Avatar
if you dont have it done u should be throwing a CEL for that. I was when we did the gsr swap on my 99 EX.
Victor Jónsson
Jun 27, 2013 10:01 PM
spongecop
Nov 17, 2010 05:41 PM
chrisna
Nov 12, 2007 08:42 PM
cioli
11
Jun 25, 2006 11:21 AM
Michalob234
Dec 29, 2003 06:10 PM
