Loss of power!
Old Feb 19, 2009 | 10:20 PM
yoda94ej1's Avatar
Icon2 Loss of power!
Ok to start of with about a week or so ago i've been noticing the motor has been struggling (z6, 168k miles) with having any power at all. almost feels like there's no oil pressure or if there is very little of it. not sure where i should start off at. bad compression no idea let me know what you all think :D
Old Feb 19, 2009 | 10:27 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Default Re: Loss of power!
Start off with doing a compression test.
Old Feb 19, 2009 | 10:36 PM
andoxviii's Avatar
x2
Any leaks or smoke?
Old Feb 20, 2009 | 02:24 AM
yoda94ej1's Avatar
Originally Posted by andoxviii
x2
Any leaks or smoke?
smokes a lil here and there and has a leak somewhere from the head but no idea where it's coming from
Old Feb 20, 2009 | 03:04 AM
V8 Eater's Avatar
do a leakdown and see how much its leaking, than investigate to see where its leaking from. bottom end and its your rings, open the tb and if air come out its your valves, bubbles in your rad and its your headgasket is what I was told before!
Old Feb 20, 2009 | 06:11 AM
yoda94ej1's Avatar
soon as the parts store opens i'll head in and pick up a few tools and go from there >_>
Old Feb 20, 2009 | 06:50 AM
bossm's Avatar
^^ do this first and then change your headgasket if that is where the leaking is coming from but most likely it is
Old Feb 20, 2009 | 07:58 AM
yoda94ej1's Avatar
just had it replaced 3k miles ago..and as far as my compression it seems fine appx 160 across em all but i'll check it again..forgot to add that there was massive corrosive buildup on the 2nd and 3rd spark plug..white
Old Feb 20, 2009 | 08:11 AM
rkcarguy's Avatar
160 isn't that good, that's getting tired. Typically see 180-210 on the JDM import D's.
Old Feb 20, 2009 | 09:02 AM
yoda94ej1's Avatar
after 3 more times across each cil....im in some pretty deep problems (looking at the motor) 100,120,150,160 compression..DOH! lol
Old Feb 20, 2009 | 03:44 PM
yoda94ej1's Avatar
Ok after i put everything back together i go to start the car and it wont fire..just sits there and turns over and over..i can smell the gas also. guess it's not getting any spark
tiemze
Dec 2, 2013 04:44 PM
keith1993may
12
Jul 10, 2013 04:18 PM
jdm inc
23
Jan 2, 2012 01:59 PM
t0kyoStatus
35
Jun 28, 2008 11:58 AM
mick
Jun 7, 2002 07:43 AM
