smoking when i hit vtec
my freind has a 95 gsr and it smokes when he hit vtec and when he rev it to 7 grand . it dose not have water in the oil and it is not over heating. it looks like he is leaking oil from the head what could it be and the coolant it full
First- This is a type r forum and some guys are very **** about it. But not me.
second it's vtec not vect.
You just answer your question. Leaking oil. Where from the head is it leaking from? Is it black or blue smoke? head gasket leaking? Maybe valve seals are bad. Is it a chipped ecu?
Check compression. Blue and white. Seems like oil and to lean or water. Try a leakdown test.
I had something like this happen before. I had three head bolts stripped my block and it smoke and leak oil.
Compression came out find because it only burn oil and water when I push it hard. Why? because the head was lifting off my block, when there was a lot of pressure. It stripped because my car over heated once.
It's an aluminum block and the head bolt is a high grade steel. Aluminum doesn't conduct heat so the stud (steel- conducts heat) get all the heat and it expand and stripped my block.
So compression might check out fine, because their is not enough pressure to lift the head. But when you floor it, smokes and leaks oil.
sohcpower1
May 8, 2016 11:08 AM
95DailyBeater
Aug 13, 2012 11:02 AM
a1320honda
Oct 8, 2007 09:11 AM
apexrift
Jan 28, 2005 11:04 AM
