A'pexi VAFC problem -no vtec
Old Aug 9, 2002 | 08:18 PM
The Poopsmith's Avatar
Default A'pexi VAFC problem -no vtec
I just finished installing a VAFC i bought. Everything is operational, I double checked all the wiring. Everything seems ok, but I just took it out for a test drive and Vtec is not activating. I messed with the VAFC and got it show VTi and VTo, VTo is activating, but VTi is not. What could the problem be? The sensors are set to 6 6, is that what they are supposed to be set too? Help me...
Old Aug 9, 2002 | 09:05 PM
Reid's Avatar
Global Moderator
Default Re: A'pexi VAFC problem -no vtec (DeeSeeToo)
Then that means the V-AFC is making VTEC engage.
You must have lowered your VTEC engagement point.
What makes you think it's not engaging?
Old Aug 9, 2002 | 09:41 PM
Default Re: A'pexi VAFC problem -no vtec (Reid)
I . I used to havhave my crossover set to 5200rpme a fields controller hooked up with upped vtec crossover, and with vtec set at 5200rpm in a GSR you can hear and feel when vtec kicks in. With the VAFC I don't hear or feel vtec kick in at all.
Old Aug 9, 2002 | 09:43 PM
uNF$@#!'s Avatar
quick test.
reinitialize the VAFC. its an option.
proceed to set vtec engagement point to be 6400-6500.
proceed to hit the rev limiter. if you feel a sudden kick, thats vtec
Old Aug 9, 2002 | 10:17 PM
CRiSP's Avatar
Default Re: A'pexi VAFC problem -no vtec (Soup ****)
make sure you set up the number of sensors...it should be 6 i believe
Old Aug 9, 2002 | 10:18 PM
CRiSP's Avatar
Default Re: A'pexi VAFC problem -no vtec (CRiSP)
wops sorry just read your post cancel out that last one by me
Ntercooled
Dec 26, 2005 07:39 PM
bchomka
Oct 31, 2004 08:48 AM
civictuned
Aug 1, 2003 04:36 PM
98R-1144
Nov 4, 2002 05:12 PM
EleanoR
Apr 17, 2002 06:06 PM
