FS//BNIB Scat rods//MSD Fuel pump//GSR brakes
Old Feb 19, 2009 | 05:20 PM
T9U4ReBgO's Avatar
Default FS//BNIB Scat rods//MSD Fuel pump//GSR brakes
Zack
(864)561-9402
Travelers Rest, SC 29690
$105 Shipped BRAND NEW!!! No box or paperwork tho!
Paypal verified!
MSD 2225 electric fuel pump. The MSD electric fuel pump mounts in line (out of the tank) with two supplied cushioned clamps for a quick and sturdy installation. The MSD fuel pump has a 3/8" inlet and a 5/16" outlet side. Wire terminals feature brass studs for secure connections. Multiport EFI systems require a stable fuel supply to maintain best performance throughout the engine's rpm range. The MSD high pressure and high flow electric fuel pump features a roller vane pump mechanism which is extremely resistant to clogging and jamming. The MSD electric high pressure fuel pump is ideal for use as a booster for nitrous applications or as a stand alone pump for multiport EFi systems on engines up to approximately 500 horsepower. The MSD high pressure electric fuel pump is made in the U.S.A. and is capable of 43 gallons per hour (162 liters per hour) at 40 psi at 5.4 amps. The picture above shows the MSD high pressure electric fuel pump.
Scat B18b/B18a rods $250 Shipped!
2-5394-1771-935-827 1.771" Journal, .935" Width, .827" Pin For B18A DOHC VTEC, ARP 2000 Bolts.
GSR front brake setup - $150 picked up
GSR rear brake setup - $150 picked up
buck02
Dec 30, 2010 09:51 PM
buck02
Dec 30, 2010 09:48 PM
buck02
Jul 24, 2009 08:40 AM
gsracer170
Jan 16, 2004 02:50 PM
