MSD Fuel Pump / MSD Fuel Pump Voltage Booster Pump
MSD Fuel Pump #2225 BNIB $100 Free shipping
Multiport EFI systems require a stable fuel supply to maintain best performance throughout the engine's rpm range. This high pressure and high flow Fuel Pump features a roller vane pump mechanism which is extremely resistant to clogging and jamming. The pump mounts in-line (out of the fuel tank) with two supplied cushioned clamps for a quick and sturdy installation. The nipple inlet is 3/8" with a 5/16" outlet. The wire terminals feature brass studs for secure connections. Made in the USA, the pump is ideal for use as a "booster" for nitrous oxide applications, or as a stand alone pump for multiport EFI systems on engines up to approximately 500 HP.
MSD Fuel Pump Voltage Booster Pump #2350 Slightly Used $175.00 Free shipping
Maintains fuel volume in relation to boost pressure by stepping up the supply voltage to the electric fuel pump
Voltage output is adjustable up to 22 volts at 15 psi of boost
For use with stock electric fuel pumps or secondary booster pumps
Affordable and effective alternate to replacing all of the injectors or ECU modifications
